Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1997 chevy 1500 pickup won't start
The truck drove fine then I stopped to visit friends then it would not start. It turns over but won't start. I changed the rotor button, distributor cap, ignition coil, crank sensor, still no fire. Sounds like it wants to fire but won't start.
    Scholar:
  • 117 Answers
You need to check if it is a spark problem or a fuel problem. Check to see if you have spark to the plugs by removing a plug wire from the dist cap, hold it 1/2 inch from the tower in which you pulled it from and have someone crank the engine over. If you have a strong spark, then it is a fuel problem. Take off the air cleaner and squirt some starter fluid into the throttle body. If it starts you have a fuel problem. Check the fuel pressure with a pressure gauge. Should have 45-50 psi depending on engine. If you have no pressure check the fuel pump fuse in fuse box. You may have a bad pump. You might try tapping the lowers part of the fuel tank with a hammer while someone else is cranking the engine over. Sometimes that will jolt the pump into pumping.
Posted on Nov 02, 2013
2 Suggested Answers
TDISLine
  • 1874 Answers
SOURCE: 1997 Chevy Express van 1500
It's clear that you have a fuel system problem, if the engine will ignite only with starter fluid. Injectors do not spray when engine cranking, even the fuel pressure is good enough = 60 psi. Then remove the fuel rail assembly with injectors and see if they spraying fuel when another person cranking the engine. If not, check the electrical power supply of injectors & repair wires, connections, ... Also verify the Engine Control Module (ECM) output power towards injectors.
Posted on Oct 23, 2010
1997 Chevy C1500 pickup won't start?
You need to have the ignition control module checked (It's inside the distributor)
Apr 21, 2013 | 1997 Chevrolet C1500
2000 chevy 1500 express van turns over but won't start when it rains
the high humidity (water) is attacking your electrical starting system, whens the last time you changed your spark plug wires , distributor cap & rotor ? how about your fuel & air filters ? cleaned your battery terminals ? try it , it will help !!!!!!!!!
Mar 01, 2013 | Chevrolet Express Cars & Trucks
1997 Lincoln Towncar, cranks but won't start?
first you need to test for spark if there is spark then check for fuel if there iis no spark have your ignition module ckecked for fuel take the lifuel line off from fuel tank to fuel lilter it is not difficult.
Jan 24, 2013 | Cars & Trucks
1997 Camry overheated, now won't start
they either need to be cleaned or u might need new plug wires
Aug 16, 2012 | Cars & Trucks
1997 Chevy 1500 won't start and there is no
i have the same thing going on with my truck i stoped at the store to put gas in and went to crank it up to leave and it would just turn over so i got it towed to my house and started looking up stuff that might make it do that , it turns over fine , after read alot of this stuff on the computer i went and got a Fuel pump no help there so i i got fuel , i have spark at the plugs , so i changed the spider still no luck , can any one give reason it is not cranking , all i can get it to do is turn over ,
Apr 04, 2012 | 1997 Chevrolet K1500
My '97 chevy s-10 won't start
Check to see if the fuel pump runs for a few seconds when you first turn the key to the "run" position. You should be able to hear it if you put your ear to the gas cap while someone turns the key. It will run for 3 or 4 seconds and then stop.
Check for spark. Easiest way it to hook a timing light to any wire and turn the engine over. There are many reasons for no spark. Most common being the coil, sensors, MAF etc.
If the fuel pump isn't running. Check fuses, wires, and finally... change the fuel pump if all else fails. You would be well advised to find one at an auto wrecker if you can. They are expensive.
Feb 06, 2012 | 1997 Chevrolet S-10 Pickup
1999 z71 1500 chevy pickup won't start
Has the check engine light come on at all ?
Jan 26, 2012 | 1999 Chevrolet Silverado 1500
My car stopped without warning or flashing lights after it started and drove for a few second. After it stopped, I tried to restart it and it won't start, it will make a cranking noise as if its...
Have you check the fuel filter?
Is there any spark on the spark plug cable? If there isn't any spark, you might check the ignition coil and ECU
Jun 23, 2011 | 2001 Jeep Grand Cherokee
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
227 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
