Question about Jacuzzi Amiga, Soaking Bathtub - 9180
Where is the reset button on the motor? - Jacuzzi Amiga, Soaking Bathtub - 9180
  • Jacuzzi Master
  • 717 Answers
There are no reset buttons on Bath Pumps. They do have a thermal overload switch in the motor so it will shut off before it burns up.
that is thermal so when it cools down it will let the motor come on again but there is no reset switch on any motor.
US Parts Center
Posted on Apr 25, 2013
If i have a bad cad cell and press the reset button would i just get a click
sounds like you have to manualy reset the burner motor. Every north american oil burners have a manual reset button,, tiny little red button located on the sides of the motor, if it needed resetting you should feel a slight click . then reset the primary once again. if youu have an electgrical tester u could always test for 115volts at burner motor upon rsetting primaryt
Feb 16, 2016 | Heating & Cooling
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Why does it pop the reset button?
The button is a current overload protection for the motor. There is a variety of causes. Defective motor windings, carbonized burnt pressure switch contacts, loose connection (e.g. cord to plug, switch terminals, motor terminals), wrong voltage supply to the motor, worn motor bearings, drive belt too tight, or defective driven machine.
I would run the motor with no load, remove the belt or coupling to the compressor pump, and read the amperes and compare to the motor nameplate rating, let it idle a few minutes and listen for bearing noise. By reading motor amperes or current while the compressor is still connected to the motor, it can be determined if the reset button/overload protector is weak. Check every electrical connection for discoloration or overheating and repair if any are found. Check the contacts of the pressure switch. If nothing wrong is found and the motor is just overdrawing current or amperes, then it is time to replace the motor, probably due to a weak or defective motor internal winding.
May 27, 2015 | Air Tools & Compressors
The canister motor will not come on but the power mate motor does. Is there a reset button/circuit breaker for the canister motor? There was a clog but that has been resolved. Bag and filters are new.
There is no reset button. You've fried the motor. If both the power nozzle and canister motor didn't work, one might suspect a fuse.
Apr 04, 2015 | Vacuums
Reset thermal
I think the question is thermal overload on a three phase motor. If a motor has a thermal overload that must be manually reset then there should be a button on the motor, often red. While the motor is de-energized (power plug removed) , push the reset button by hand.
Jan 04, 2014 | Dryers
Reset switch location
the reset button is in the on switch what you need to do is unplug from wall socket then press the on button down hard to reset.
Aug 14, 2013 | Dyson Vacuums
Is there a motor reset button on the whirlpool dryer
1) Sometimes some motor have reset button , other NOT
2) See the w. diagram attached. God bless you
3) Download the instruction manua go www.fitness.manualsonline.com or www. retrevo.com
Jun 14, 2012 | Whirlpool Dryers
Compool 3600 Spa side remote
Do not reset while the motor is running. Reset the CP 3600 when the power is on but with the motor off. OK.
Jun 07, 2009 | A.O. Smith SQ1102 Pool Pump Motor
La Pavoni Coffee Grinder PA Burr
usualy reserable termic fuses are attached to body of motor, or inside the winding wires of motor.
  1. if it is attached to motor body than you should reset yourself, usualy they are black, round colour with red reset button on center. it is enough to push that red button and you reset it.
  2. if it is in winding wires it should reset when motor temperature drops, if that is not the case than you should consult winding expert for that, in your region.
Oct 15, 2008 | La Pavoni PA-BURR Electric Burr Grinder
Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Jun 13, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jacuzzi Amiga, Soaking Bathtub - 9180 Logo
94 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
