Can you hook ethernet up to emachine etower667ir
Wont allow me to share my internet , its hooked up to wifi i want to run a cord to my xbox to give it internet possible?
Yes this is possible. You will need to bridge connections between your WIFI adaptor and Ethernet ports.
Navigate to Network connections, select both your WIFI adaptor and Ethernet adaptor. Now right click and select "bridge connections"
Take care!
damnor01
Sep 11, 2012 | eMachines E620-5885 Notebook
Emachine doesn't recognize the ethernet cord when plugged in
Sounds like the integrated ethernet port has gone bad. You can install a new ethernet card in one of the PCI expantion slots. Then plug the ethernet into the new card, this should take care of the problem. You can not repair a bad integrated ethernet port.
Feb 20, 2012 | E-Machines eMachines Desktop PC
Emachine t3626 internet port can it be replaced
Absolutely!
The Ethernet port on your eMachines is part of the motherboard.
It is attached directly to the motherboard.
The eMachines T3626 Desktop PC, is supposed to use an
ECS MCP61-P (AM2) motherboard. (Cannot verify)
(Elitegroup Computer Systems. (AM2) refers to the processor socket )
http://www.ebay.com/itm/MotherBoard-eMachines-T3626-T5062-T5234-W3622-/320528791641
(Also scroll down for a larger photo of the motherboard )
The Ethernet port is in the group signified by the letter A, on the left.
The group signified by the letter A, is in the I/O area.
Input/Output area. This is where Input, and Output devices are attached, TO the motherboard. (Using the motherboard's chipset)
Now look down the motherboard, to the two long white slots.
These are PCI slots. Signified by the letter I ( i )
If one of these slots is not being used, plug in an Ethernet Card, that is PCI.
If both of these PCI slots are being used, use the small white slot above them, signified by the letter H.
This is a PCI-Express x1 slot. If it is available, use it.
Use an Ethernet Card designed to fit, in a PCI-Express x1 slot.
Example;
PCI Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=771339&CatId=1175
PCI-Express x1 Ethernet Adapter Card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
[ Note*
The PCI-Express x16 slot that you have, (Orange in color, above the white PCI-Express x1 slot), is for a graphics card.
It is ONLY for a graphics card.
The PCI-Express x1 slot is NOT used for a graphics card ]
For additional questions please post in a Comment.
(If you would like the proper procedure for installing a Ethernet Adapter Card, in your eMachines T3626, also state in a Comment)
Regards,
joecoolvette
Dec 19, 2011 | E-Machines eMachines Desktop PC
Can't find a driver for the network / Ethernet port for emachines w3107 on the emachines website
It's on the eMachines website...you just have to download the NVIDIA nForce Chipset Package...Then extract it and it will be the first folder in the package (Ethernet). The whole package is 35.3MB so it may take a few minutes to download depending on your internet speed. Hope this helps!
Jul 01, 2010 | E-Machines eMachines Desktop PC
Just got a emachines T1150 desk top tower doesnt have earthernet port how do I hook up to Net gear modem to run on intranet
You would need to fir an ethernet card there should be spare slots on the motherboard, and also increase the memory from 128mb.
Dec 17, 2009 | E-Machines T1150 PC Desktop
Emachines model t4010 window s xp. need a driver
plz kindly specify your ethernet card model so that you may get assistance
Nov 10, 2009 | Computers & Internet
Cant connect to internet with emachine through lynksys router.
you will have to add an ethernet card to your emachine if it will take one, or you might be out of luck
Apr 04, 2009 | E-Machines (T2958) PC Desktop
Ethernet controller driver for an emachine t2460
Description Integrated Ethernet Driver File Type Original Driver Version 5.504.613.2002 Operating System Windows XP Driver File Download (1.11 MB)
And here is the support site if you need anything else
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2460
Good luck
Nic
Mar 28, 2009 | E-Machines eMachines Desktop PC
Emachines T3624 Ethernet controler
well, if you have a built-in NIC card, usually you should have a CD that has the driver for you ethernet controller.
or you might want to visit the link below to download your driver
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3624
I think the one you need is that Intel 845GV Chipset Driver
Mar 25, 2009 | E-Machines eMachines Desktop PC
Ethernet driver needed for emachine 3240
try this page...
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1672&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Apr 21, 2008 | E-Machines Computers & Internet
Computers & Internet Logo
770 people viewed this question
David Payne
David Payne
