Question about Acer Aspire 3000 Notebook
MAIN MOTHER BOARD OVERHEATS AND THE SCREEN WON'T GO ON NO
LIKE IF YEW CONNECT A USB CABLE TO IT IT WORKS ETHERNET CABLE IT WORKS BUT THE PROBELM IS DAT THE SCREEN WON'T COME UP ...IT JUST STAYS OFF I CHARGED IT ND REMOVED THE BATTERY FOR 10 MINS BUT NOTHING
Unknown device name
Dear Dzejna
Pl. connect the USB cable to the port(port mounted on system mother board.) at the back panel of the desk top pc. Try to implement maintenance operation fro the system program. follow the steps, if its display (Say USB not connected of device not connected) Then there is a problem with Main Board of the printer and its need replacement. (try with other system.
If your desktop has replaced mother board for any hardware cause then it also happen the printer main board gets damage th usb port.
Thanks.
Jan 13, 2012 | Samsung SCX-4300 Monochrome Laser...
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
External hard usb connection with another computer
USB cables/devices were _not_ designed for computer-to-computer connections. Don't try it.
Instead, buy a "cross-over" Ethernet cable, to connect the network-ports on the two computers.
May 31, 2009 | Intel Motherboard
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
4100 Modem telling me to install ethernet adapter
You do not state if the ethernet had been working before. If this is the first time to use the port on the computer, it often needs to be turned on in the BIOS of the mother board.
Nov 26, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
I am having problems at times, connecting on the internet, and other networks online. (i.e.)an icon would appear and suggest an error/data was made and being reported, and automatically swicth me back to...
Cable has changed it's policy and standards many times in the past
if you have a cable modem you will most certanly need to decide
if you're going to be using the cat5 ethernet connection or the USB connection cable
if you have an onboard ethernet adaptor or a PCI ethernet adaptor
it's best if you use the cat5 connection of the cable modem
if you have no ethernet adaptor , you will need to use the USB connection of the cable modem
and connect that to your computer , which will most deffinately require that you have working
USB ports and at least service pack 2 loaded to enable USB 2.0 , and a driver from the cable
modems driver CD
if you're using a router , use the cat5 connection of the cable modem
( make sure you contact your ISP to walk you through the setup proceedures )
Az Selah ..
Sep 17, 2008 | Computers & Internet
Can usb substitute for the ethernet connection?
Perhaps buy one on eBay (possibly $60) and pull it's interface circuit board, to replace your bad one:
http://search.ebay.com/netdisk
Apr 10, 2008 | Ximeta NetDisk (NOWWL) 160 GB Hard Drive
Broken Ethernet Adapter
They sell USB to Ethernet adapters that you can use. If you want to replace the adapter yourself you will have to strip the laptop down to the mother board, then proceed to de-solder then solder the new one back onto the board. You can but the replacement piece from either http://sparepartswarehouse.com if they have your make and model, or you can get it from your laptop's distributer.
Feb 21, 2008 | Dell Inspiron 1000 Notebook
Acer Aspire 3000 Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
