Question about Gateway Computers & Internet
I DID THE BOOT UP WITH THE THREE RECOVERY DISCS, AND NOW ALL I GET IS A BLACK SCREEN WITH A FLASHING CURSOR
I was using my computer, and all of a sudden it just shut down, and wouldn't start back up.. So I switched it back on and pushed the"F12" and put in the #1 disc of the recovery, and kept on going till all 3 discs were done. Then the computer turned itself off, then back on, and now all I get is a black screen with a blinking cursor---Please help me. My computer is 18 months old, it WAS running on Windows 7, and hopefully it will be again. Thank you
  • 3,799 Answers
The problem was most likely a heat problem. So, that problem is still there. Switch it off and remove the cables. Then, take off the side panel and look at all the dust inside. Using a very soft 1 inch paint brush, gently loosen the dust on the fans and around the insides. (You could use a can of air from a computer shop to do the same job, this will stop you causing any damage to the delicate parts on the motherboard.) Then re-assemble the case and connect the cables turn it on and see what happens.
Posted on Apr 21, 2013
  • 62 Answers
SOURCE: Screen Wiggles, CPU Shuts Self Off, Powers Up Very Slowly
#1 Sounds like a video card resolution setting problem. This can happen when the settings are too high for the monitor. What size is your monitor?
#2 Sounds like hibernation. You can adjust the power settings if you right click your desktop and select "properties" . The select screen saver and then power settings.
#3 Sounds like the bios settings have been modified to boot from other places than the hard drive. Make sure nothing is in the computer when you boot like CDs, Floppy disks. When the computer first turns on hit "F2" to enter the bios. Then look for boot order in one of the drop down menus at the top. It will tell you how change the boot order usually on the right hand side ont he screen.
I hope some of this helps you.
Regards
Posted on Dec 06, 2008
rylee_smith
  • 8619 Answers
SOURCE: Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Posted on Feb 11, 2009
  • 124 Answers
SOURCE: Sony PCV-A11 desktop won't boot up to windows. I
Use your installation CD for Windows that came with your computer, and boot to the CD. (Usually, pressing the F12 key will offer your boot options such as "Boot to CD.")
Once booted on to the CD, it will offer you several options - Do NOT reinstall Windows - you want to choose the Repair Option.
When the repair stuff has loaded (You may have to select which volume you wish to work on, if so just pick the number that is next to your C drive.) and you are at the prompt that looks like "C:>" you will want to type in the following, without the quotation marks.
"chkdsk c: /r"
It will take a while for it to work all its magic, but that should fix your problem!
When it is finished, you can simply push the power button on your computer to turn it off.
When you next turn it on, it should be happier.
Posted on Jun 13, 2009
frankzcomput
  • 268 Answers
SOURCE: DELL DIMENSION 5150 SOMETIME WILL NOT SWITCH ON
You need to get into the bios of your system and setup the date, time, and disable floppy boot. You may also want to clean any/all dust/dirt/hair from your system and make sure your fans are working. Sounds like your cmos battery failed (you changed that) and that your processor/motherboard is failing due to overheating
Company Site http://www.attechcomputers.co.cc
Posted on Jun 18, 2009
  • 99 Answers
SOURCE: windows wont boot. switches to a screen with
Try to find a system restore on the computer without using the disks. Restore it to a previous time maybe a month ago if possible.
Posted on Aug 01, 2009
Pc wont boot
You didn't post the Make, Model of the computer. Do a System Restore/recovery.
Feb 23, 2013 | Computers & Internet
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click start > all programs > accessories > system tools > system restore
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
I have a m1730 i purchased 2 years ago,and it is now out of warranty.it recently would not boot up properly and would only show a black screen and the cursor.i performed a full hardware diagnostics test...
Try to boot your computer first to safemode and from there, at least you will be able to back up all your files, then reinstall the whole operating system using the recovery disc that came with the computer, do a clean install by booting from the disc itself.
Hope this will help...Please rate...
Jan 20, 2011 | Dell XPS M1730 Notebook
Black screen with blinking cursor after Acer flashes during start up. Loaded recovery disc and all seemed to go well but when I restarted it does the same thing.I can get to Bios from F2 but again that's...
this problem occurs when while booting some USB mass storage device is connected with the laptop so disconnect devices like printers or flash drive while booting and you can also do this by a setting in BIOS to stop booting from flash drive
Oct 17, 2010 | Computers & Internet
I have an Acer Apsire 6930 and a few weeks ago the screen went black and the computer will not boot. I ordered and received the recovery discs from ACER, but the computer won't even boot/run from the...
Most probably the intergrated Graphic on the mainboard of your Laptop is faulty. Too bad, you have to replace it from ACER or any authorised Vendors.
If the cost is too expensive to repair, get a new Laptop/notebook.
Aug 28, 2010 | Acer Computers & Internet
I was trying to restore to factory settings. Now screen is Black background & has Windows/RM> and cursor is flashing how do I get past this point to restore
Restart your computer, press F8, advanced boot options menu will be seen.
1> Select REPAIR and then STARTUP REPAIR.
2> If it does not works then again restart your computer and press F11. Use the internal recovery partition to format the windows partition of your hard drive by selecting SYSTEM RECOVERY.
3> If it fails to solve again, use your or order a set of RECOVERY DISCS for your system.
It will solve every issue............
On faliure again, contact HP support centre, or your nearest HP/Compaq service centre
Mar 27, 2010 | HP Mini 1000 Netbook
Black screen with flashing cursor
It may be because of your hard disk damage or OS problem. Try to install a fresh copy of XP from a cd. boot from XP cd and install .
Apr 06, 2009 | Toshiba Satellite M35X-S311 Notebook
Recovery disc will not respond in my computer
When you used it before, did you have all three CD drives connected? If not, try unplugging two of them.
Aug 09, 2008 | Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
