Question about Casio Music
My Casio ap65r won't produce sound when turned on
Only the power light comes on. The other lights are out.
3 Suggested Answers
  • 5603 Answers
SOURCE: Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Posted on Jul 25, 2010
SOURCE: Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work.
The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
Posted on Mar 22, 2012
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
Casio keyboard won't power on
If batteries or power adapter does not power up the keyboard...possibilities are...if it has a fuse inside or fusible link check it.replace if blown.Another possibility is power component has a short. maybe from constant movement of power plug into keyboard.sometimes just by inserting the plug and wiggling it can solve the issue..having this fixed by a technician can cost a lot of money.but,if your keyboard`s value is less than the cost of fixing it,might as well replace your instrument.
Feb 21, 2012 | Casio 76 Key Smartmedia Keyboard
Dec 20, 2011 | Chauvet Intimidator 1.0 Dmx-600 512...
I own a Yamaha YPT-220 portable keyboard. The "c", "b" and "f" keys (all octaves) just stopped producing a sound. Anyone else have this problem?\r\n The dealer's service...
That's the thing with today's electronic and why warranty length is so important. Where did you buy your keyboard? It's strange that they won't fix it if it's still under warranty. My Casio CTK-2100 came with 1 year free service and they fix one key that stopped function in few days. I'm pretty sure Yamaha has the same warranty length. You sometimes have to be very persistent with them though...
Jul 18, 2011 | Yamaha Full-Size Keyboard
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
I have a casio keyboard WK 3000 and when it is powered up, the screen is frozen. When the keys are pressed, no sound comes after. Also when i try to shut the power off, it doesn't turn off. The only...
Make sure you use ONLY the correct adapter for power. Too small an adapter might cause it to light up but will not operate the unit. The correct adapter should say AD12 on it. It is a 2 volt, center pin minus, and probably 1 or 2 amps capability. Nine volt adapters used with pedals or universal adapters will NOT work with the WK3000.
Jun 26, 2011 | Music
The active light does not light up when I plug my guitar in and no sound comes out from the talkbox ... But the guitar sound can run through it to an amp where the guitar sound comes out
It sounds like you have NOT connected the power adapter to the box to power it. The guitar sound won't be too loud as you run the hose to your mouth and pick up the sound with a microphone such as a Shure SM57 which then goes to your amplifier. Without the power adapter the internal amplifier will not produce any output.
Jan 08, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
My casio lk-45 has no sound, but all the lights work. Could it be the adapter?
Yes it could be. Drop voltage adapter can cause power/pre-amp not work properly, but still can power up the lights.
There maybe power supply circuit failure inside LK45 and also power-amp problem.
Oct 22, 2010 | Casio Lighted Keyboard LK90STADMC
Jul 20, 2010 | Casio Music
My casio ct670 ToneBank keyboard isn't making much sound
Check that you don't have old batteries in the unit. Also that the auto power down is not activated.
If using a power adapter make sure it is the RIGHT one, both in polarity and current rating.
Sep 20, 2009 | Casio Music
Music Logo
65 people viewed this question
Top Casio Music Experts
Ben Armstrong
Matthew Spark
Matthew Spark
Are you a Casio Music Expert? Answer questions, earn points and help others
