Question about Toshiba Office Equipment & Supplies
Toshiba 2860 copier, paper does complete the transfer process.
I replaced the drum. Now the paper does not complete the transfer process The copier shuts down approx 1 inch or less before the trailing edge passes through the drum. The paper does not completely pass the imaging drum before a jam signal is issued.
    President:
  • 1,126 Answers
Did you get the drum shaft reinstalled and latched? If not, the drum won't rotate correctly which will cause poor transfer (smudged image) and jamming.
Posted on Jun 13, 2009
My coppier is not working with the colour documents .. its looks very dark and the image is not reconised ..
try to clean the mirrors inside
if still dark and it makes over 50000 paper you need to change the drum & developer & blade
Jun 15, 2011 | Toshiba 2860 Copier
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
How do i clean my Toshiba 2860 copier? When i print it comes out very dark and it gets just a little lighter with each copy. i emptied the used toner and cleaned the 2 corona wires. Is there anything else...
Your user manual should list a "Clean Drum" command on the menu of the printer. If you don't, you can purchase laser jet cleaning sheets at any office supply store.
May 15, 2010 | Toshiba 2860 Copier
Date of manufacture toshiba 2860
1997.
OPC drum life estimate 80.000 copies,Toner 7.500 copies,Developer replace every 80.000 copies.
Oct 07, 2009 | Toshiba 2860 Copier
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
Toshiba e-studio 162d makes smudgy black margin
Hello sir; you do need a drum blade to replace at least.
May 11, 2009 | Toshiba 2860 Copier
Can you produce me a copy of toshiba 2860 service manual?
Copier service manuals can be purchased from www.justmanuals.com.They are a pay site but seem to be reasonable.Good Luck
Apr 02, 2009 | Toshiba 2860 Copier
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
65 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
