Question about Husqvarna Chain Saw 20" Bar
Weak spark on 55 rancher chain saw/ airgap on magneto
It has yellow spark wont fire the plug to make it start.Put plug in another saw runs fine . What the airgap on the magneto?
  • 1 more comment
  • mmyers23 Mar 18, 2009
    I have md#44 &51 44 gets fule & has spark wont start same with the 51
  • RDPrimeaux May 03, 2009
    I have the same problem, with a model 51. 2 separate plugs will not fire, yet they spark on other saws. A spark tester lights up as if it has spark. I removed the coil, cleaned the flywheel, cleaned the coil, and still the same. I will assume that the coil is weak.
  • Anonymous Mar 31, 2014
    fires but will not run
  • 181 Answers
The air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Posted on Mar 12, 2009
My john Deere turns over but want start
If it's a single cylinder engine, my first guess is the magneto is defective. Other possibilities are defective spark plug or spark plug wire (from magneto to plug). Verify also that the fuse is good.
Jun 17, 2015 | John Deere Garden
Poulan chainsaw not getting any fire?
check to see if your magneto is rusty if so clean with fine grit paper if still does'nt fire may be time to replace the magneto
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Hard starting husqvarna chain saw 450 rancher, is drowned
Take plug out of saw, ground it out on metal cylinder, slowly crank saw and see what kind of spark you have. Quick,bright blue fire is good, yellow or huge kernel fire is not. No fire is ignition module. If soaked with gas change plug if that don't do it, it is time to put a kit in the carberator.
Feb 01, 2014 | Husqvarna Garden
Troy built tiler won't start!!
What is the method your machine uses to decide when to fire the spark plug? Does it have a magneto, and/or ignition points under the flywheel, or a crankshaft postion sensor?
Apr 18, 2017 | Computers & Internet
Riding mower wont start
Hi Pry
The spark comes from the Magneto. Follow the spark plug wire and you will find the magneto at the end of it
The first thing you should check though, is the safety kill switch. There is a pressure switch in the seat that kills the engine in the event the driver falls off.
You need to be sitting on the mower to start it.
If the switch is ok and you still get no fire, it's the magneto.
Best regards,
Mike
Sep 07, 2009 | Garden
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
It wont spark at all. No fire. Just put a new spark plug so that's not the issue. This lawnmower is only 1.5 years old. Thanks
Could be magneto bad, wire from magneto bad, ground on magneto bad, or the clearance between the flywheel and the magneto is rusted up if it was outside. Clean flywheel with sandpaper and set magneto gap using a match book flap.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
My chain saw wont start just changed the magneto and still wont start
IF YOU ARE GETTING FIRE TO PLUG TRY A SHOT OF STARTING FLUID IN AIR BREATHER BE SURPRISED HOW MANY IT WORKS ON
Nov 26, 2008 | Poulan Pro Chain Saw 46cc 20"
Husqvarna Chain Saw 20" Bar Logo
1,220 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
