Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Replace aqualink spa side switch - Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
    Top Expert:
  • Jandy Master
  • 4,262 Answers
Unplug the spaside plug from the bezel board tape a strong string to it remove spa side remote at spa and pull the cable back through the conduit attach the new wire to the string pull it back through to the aqualink then hook back up to the plug then plug back in
Posted on Mar 05, 2016
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
Posted on Aug 06, 2009
  • 990 Answers
SOURCE: Jandy Aqualink rs4 when set on auto the system
Go through your menu again and reset. These have defaults that may be causing the trouble if the power went out or your battery backup is old. Check this and let me know and we can look further. Your menu should help to walk you through problems, it is very user friendly. Hope this helps, let me know.
Posted on Nov 07, 2009
  • 2976 Answers
SOURCE: Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Posted on Nov 14, 2009
  • 366 Answers
SOURCE: Jandy aqualink rs4: pool has been winterized with
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
  • 8404 Answers
SOURCE: how do you drain the spa?
There is probably a drain valve somewhere near the control panel ... forgetabout it ... too slow.
Best way is to get a small pump and pump it away. Next best is wet dry (shop vac). My favorite is siphon ... dont have to buy anything or drag anything out ... only a hose. By the time my water is out ... I have had time to do the necessary surface cleaning and waxing.
Posted on May 16, 2010
Blower turns on by itself at all times of the day
if you have a 4 button spa side remote unplug at aqualink if it goes away replace 4 button switch
Feb 12, 2013 | Jandy AQUALINK RS TELELINK KIT
Aqualink RS4 keeps turning on and off even though all programs have been cleared.
This issue sounds tricky. I recommend you callthe Jandy technical support at 800-822-7933 and they should be able to help youfigure this issue out.
I hope this helps.
Sep 12, 2011 | Jandy Aqualink Rs4 One Touch Control...
I have a AquaLink RS8 and the spa light, filter light, and spa come on all the time. Only way to stop it is to go to service mode outside.
try disconnecting the spa side remote inside the aqualink look at the diagram on inside of front cover water in conduit or bad spa side will do this if it corrects by disconnecting replace spa side switch
Jun 29, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
I have this jandy aqualink one touch rs control in my pool, but suddenly start to turning on and off by itself
GO TO THE MAIN PANEL AND OPEN IT DISCONECT THE SPA SIDE SWITCH LEAVE OFF AND SEE WHAT HAPPEND FOR A FEW DAY IF OK REPLAACE SWITCH
Oct 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
23 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
