Question about Casio FX991ES Scientific Calculator
How to remove G fix sci - Casio FX991ES Scientific Calculator
  • Casio Master
  • 8,068 Answers
You may want to reset the calculator. Press the key sequence SHIFT 9. Do not be surprised if you see that G has been replaced by D. These two remind you that the angle unit is set to gradian (G), degree (D). There is a third angle unit, the radian (R).
Posted on Apr 21, 2013
HOW CAN I SOLVE FIXSCI?
Both FIX and SCI are lit? What happens if you press SHIFT MODE then select either SCI or FIX?
Jun 17, 2013 | Casio Fx-991es Scientific Calculator
I want to solve FIXSCI. How can i solve it?
Both FIX and SCI are lit? What happens if you press SHIFT MODE then select either FIX or SCI?
I want to remove rad and sci symbol from casio fx-901 calculator display
For removing SCI symbol press following keys Shift-->Mode-->8-->1.
You can't remove RAD symbol, you can only replace it by DEG or GRA.
Aug 22, 2011 | Casio FX-115ES Scientific Calculator
How can i get fix off my calulator
To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
Jun 23, 2011 | Casio FX-300MS Calculator
HOW CAN I GET FIX AND REG OF MY CALULATOR.I AM USING FX 300MS.
Press MODE 1 to get out of the regression mode and into the standard calculation mode.
Jun 23, 2011 | Cameras
How do I set to Scientific Notation?
Press 2nd [SCI]. You can specify the number of digits after the radix point by pressing 2nd [FIX] and a digit key.
SCI is on the 5 key, FIX is on the decimal point key.
Jan 27, 2011 | Texas Instruments TI-30XA Calculator
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Mar 03, 2010 | Casio Office Equipment & Supplies
How do i change from whole numbers to decimal places?
Press the [MODE] key repeatedly until you reach a setup screen that shows FIX SCI NORM with 1 beneath Fix, 2 beneath SCI, and 3 beneath NORM.
Press [1] to select (FIX) and follow it by the number od decimal digits you want (2 or 3 seem about right).
Mar 02, 2010 | Casio FX-115MS Plus Calculator
How to switch off the REG and Sci function
press MODE then select CALC then COMP to remove REG.
press MODE again select DISP then NORM1 to remove SCI.
May 20, 2009 | Casio FX-115W Plus Calculator
Turn off sci
To turn off SCI, press the MODE button, then press 9. MODE 9 is the function for NORM, which means normal use. DEG is always on, but if you want to clear SCI or FIX, MODE 9 will clear these.
Nov 19, 2008 | Casio FX-250HC Calculator
Casio FX991ES Scientific Calculator Logo
115 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
