Question about Dell Computers & Internet
Clean my hardrive
How do i clean the hardrive on my computer
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Do wan't to clean or erase ?
http://download.cnet.com/windows/wisecleaner/3260-20_4-6288537.html
http://www.filehippo.com/download_eraser/
HERE ARE TOOLS CLEAN OR ERASE A HARD-DRIVE
Posted on Apr 21, 2013
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Tip
Hardrive Failure
When ever you get a hardrive failure message or Beeps coming out of your computer it is best to go ahead and replace your hardrive because it is most likley corrupted
on Jul 15, 2010 | Computers & Internet
Xbox 360 stops loading (freazes) a saved game at dif. pts.s of same save?
your hardrive mite be sorupt or damaged. see if it dose te same on another consel with te same game. olug ur hard drive into another consel nd play the game till itts saves see if it still freezes. if it doesnt the its your consel. mite be having some problems wit data transfer to your hardrive. if it still freezes its either te game or your hardrive. clean the game wit some scratch remover. sometimes scratches cant be seen but will still efect the gameplay. if it still freezes then its your hardrive. you mite wana try getting a new hardrive
Dec 14, 2009 | Microsoft Xbox 360 Console
I connect my sansa e250 into my computer and the mp3 player says connected but i see no sansa hardrive and the computer doesnt respond .
Turn Sansa off. Unplug USB and make sure its clean. Plug back in as normal. If no hardrive comes up go to My Computer and look for it and troubleshoot if necessary.
Finally, repeat this action above accept when you turn MP3 off, hold button for 15 seconds - release and then turn back on.
Nov 05, 2009 | SanDisk Sansa e250 MP3 Player
Low speed working
If you would like to take a drastic measure to fix this problem, just take everything you have on your computer that you want to keep and save it. Burn it onto a CDR, DVD or put it on an external device such as an external hardrive or a memory stick. Make sure you have all the dics that came with your computer. Such as the Operating system CD and the CD which contains your drivers. I believe that disc is called the Dimension Resource CD. Then wipe you hardrive clean. I used a program called D-ban to do this on my computer. It was free and I found it on the internet at http://www.dban.org/ Now that your hardrive is clean and you saved the stuff you wanted to keep, just reload windows by placing the operating system CD into your cd drive and reboot your computer. When the first window opens hit your F12 key then boot from the CD drive. Folow the onscreen directions and this will reload your operating system. Then install all the drivers from the Dell dimension resource CD. WOW!! Now your computer will run like it is brand new. It will seem like you just bought it new. I have done this several times to my computer. It is a little time consuming but it works like a charm. It will also remove a computer virus if you have one.
Other than the solution above I have used the restore points on my computer. If you have set a restore point on your PC from an earlier date you can go back have all the settings changed to that date. Here is a link to information on how to do a system restore. http://www.computeractive.co.uk/computeractive/q-and-a/2230699/pc-help-system-restore This is easy to do. Good luck with eveything.
Mar 15, 2009 | Dell Dimension 2400 PC Desktop
Need to clean up space on hardrive
you need to delete the songs, videos and pictures those are the type of files that make space. but before you do that makesure they're backed elsewhere if you need them.
Mar 03, 2009 | HP Pavilion a350n PC Desktop
Need to clean hardrive on computer
click on the start button and then click run and type %temp% and you will get the folder and please delete all files inside that folder..
click on start->allprograms->accessories->system tools->diskcleanup
please follow the above steps it will solve your issue
Mar 03, 2009 | 1998 Plymouth Voyager
How can you tell if your hardrive is damage? i have a toshiba satellite m50 laptop. I also want to know if the hardrive is calculated in percentage. I took my laptop to get it repaired and i was told that...
try using the basic utilities that are on the computer. disk clean up and scan disk. Scan **** should give you the info on how bad your hard drive really is. And yes any electrical connections installed improperly could cause harm.
Nov 30, 2008 | Toshiba Computers & Internet
Hardrive not recognised my computer yet the power light is on
go to control panel.. go to Administrative tools.. then .. go to computer management.. on the left pane.. click disk management.. u can detect all ur drives in here including those who are not seen by your MY COMPUTER..
Apr 13, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
