Question about Polk Audio PAD5000.5 900W RMS, 5-Channel Class D PA Series Amplifier
Polk pad5000.5 amp going into protection
I have just finished installing my stereo in my car and at any kind of loud play my amp is shutting down. it did it in the process of setting gains so there was no real heat involved. the amp is running a set of focal k2 at 2ohm for the front s set of hertz coaxials in the rear at 4 ohm and just the factory sub at 2 ohm. All the signal comes from a pioneer avh 2550bt and all yhe wires and interconnect are stinger, 4 gauge power and ground,paint sanded to bare metal for the ground. everything is brand new and im not too sure what could be causing the problem as the amp is 2 ohm stable on the front 4 channels and 1 ohm stable on the sub channel. any help would be greatly appreaciated,thanks in advance,Jake.
    New Friend:
Jake I am having the same problem What was the solution if you don't mind me asking
Posted on Apr 08, 2014
My sound plays for a while and then the amp goes into protection
Try a different set of speakers or if it keeps going into protection you have a channel going bad.
Jan 14, 2014 | Audio Players & Recorders
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
My Kenwood amp shuts down and goes into protection mode after I play it for a minute or so. I have it cranked pretty loud. I have checked out my speakers and there are no shorts. I have a preamp between my...
could be you don't have enough voltage going into the amp or it could be the pre amp in between. if your voltage is below 11 volts then you need more voltage. you should have at least 12 to 14.4 volts.or you might have a small short in your amp.
Aug 03, 2010 | Kenwood KAC-9102D Car Audio Amplifier
AMP GUARD ON
I'd say go back to the guy who installed and get him to do it right. He's either left some wires exposed so they are intermittently touching, or has an open connection to one of the speakers. The amp will shut down to protect itself. He may also not have wired the speakers correctly. Some systems don't work unless both hot and ground wires run directly to each speaker. Some installers run only a hot line and use the car body for ground. At higher powers this can cause amp shutdown or keep it from working at all. In any case the installation wasn't done correctly.
Apr 22, 2009 | Clarion M475 CD Player
Red protection light is on constantly. the light won't turn green
is the remote source have enough amp to triger amp seem like that is you prob and chk you spk wire and rca too-
Mar 24, 2009 | Polk Audio PA250.2 Car Audio Amplifier
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
I love loud music
i have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
Oct 28, 2008 | Alpine CDA-9856 CD Player
My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes...
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
barneyluc
Oct 01, 2008 | Audio Players & Recorders
Mach 460 stereo problem
That particular stereo system have self powered speakers. The speakers amplify themselves. You may have one of the speakers amp go out.
Aug 16, 2008 | 2004 Ford Mustang
Polk Audio PAD5000.5 900W RMS, 5-Channel Class D PA Series Amplifier Logo
75 people viewed this question
Top Polk Audio Televison & Video Experts
Are you a Polk Audio Televison and Video Expert? Answer questions, earn points and help others
