Question about Acer Aspire 5610-4648 Notebook
\window\system32\ntknlpa.exe Trying to reinstall windows vista and getting black sreen stating a recent harware or software change my be the cause, followed by... \windows\system32\ntkrnlpa.exe 0xc00000e9 windows failed to load because the kernel is missing or corrupt Can anyone help ? Please !
    Problem Solver:
  • 18 Answers
Hope its under warranty probably a failing hard drive.
Posted on Mar 12, 2009
    Genius:
  • Acer Master
  • 1,102 Answers
Reinstall using ac power cord
with cd in drive restart pc
then follow instructions when asked to delete partion you want to delete follow instructions
let me know
COMPUTER ISSUES
...enter to continue.
if it doesn't recognize the hardware, you will need to the *********** probably
Jul 25, 2017 | ASUS M5A99X EVO Board FX Socket AM3 8-Core...
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
SERIAL NUMBER
1) Run wga tool to check - genuinity , type of copy (OEM/Retail)
Link :
http://go.microsoft.com/fwlink/?linkid=52012
Shortlink :
http://downloadwgadiagtool.notlong.com
2) Check date/time
Do the below troubleshooting steps in safe mode
3) Check the "value data" for the following keys under HKEY_CLASSES_ROOT\.htm
1. Default
2. Content Type
3. PerceivedType
- Double click each of the above keys
- check the value data (default value data)
Defaut = htmlfile
Content Type = text/html
PerceivedType = text
- If the value data is different, change it to the above default value
4) Reregister the following dll files
regsvr32 licwmi.dll
regsvr32 regwizc.dll
regsvr32 licdll.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 msxml.dll
regsvr32 shdocvw.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 initpki.dll
5) Rename/replace the dll files
rename c:\windows\system32\licwmi.dll licwmi.old
rename c:\windows\system32\regwizc.dll regwizc.old
rename c:\windows\system32\licdll.dll licdll.old
rename c:\windows\system32\wpabaln.exe wpabaln.old
expand d:\i386\licwmi.dl_ c:\windows\system32\licwmi.dll
expand d:\i386\regwizc.dl_ c:\windows\system32\regwizc.dll
expand d:\i386\licdll.dl_ c:\windows\system32\licdll.dll
expand d:\i386\wpabaln.ex_ c:\windows\system32\wpabaln.exe
copy c:\windows\system32\licwmi.dll c:\windows\system32\dllcache
copy c:\windows\system32\regwizc.dll c:\windows\system32\dllcache
copy c:\windows\system32\licdll.dll c:\windows\system32\dllcache
copy c:\windows\system32\wpabaln.exe c:\windows\system32\dllcache
6) Initiate to activation tool
- Create a new dword value under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
NT\CurrentVersion\Winlogon
- dword value named : Activation Required
- set the dword value as : 1
(or)
- goto HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current
Version\WPAEvents\oobe timer
- change atleast one digit of oobe timer value data
7) Delete RESET5 keys
- start > search tool > search for reset5.* > delete all the files
8) Rename/replace WPA.DBL file
ren c:\windows\system32\WPA.dbl wpadbl.old
MGA Diag : http://go.microsoft.com/fwlink/?linkid=52012
Validation tool : http://www.microsoft.com/genuine/diag/
Regards
Apr 27, 2012 | Microsoft Windows Vista Home Premium with...
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
How to remove windows genuine error from windows7
Solution 1
Lauch Windows Task Manager.
End wgatray.exe process in Task Manager.
Restart Windows XP in Safe Mode.
Delete WgaTray.exe from c:\Windows\System32.
Delete WgaTray.exe from c:\Windows\System32\dllcache.
Lauch RegEdit.
Browse to the following location:
Windows NT\CurrentVersion\Winlogon\Notify
Delete the folder 'WgaLogon' and all its contents
Reboot Windows XP.
Note: With this method, you may be prompted to install WGA Notifications again which can still be unselected.
Solution 2
1-Launch Task manager
2-End process WGAtray.exe
3-Quickly restart in safe mode.
4-Click start, then Run. Type regedit and click ok.
5-Click HKEY_LOCAL_MACHINE
6-Click Software, microsoft, windowsNT, currentversion, winlogon, notify.
7-On the right hand side find folder WGAlogon and delete it and all of its components.
8-Restart in normal mode.
9-Go to c:\windows\system32 and delete WGAtray.exe file.
10-Next to it should be WGAlogon.dll, delete this too.
11-Delete from recycling bin and reboot.
This should have solved the problem but i advise switching your automatic updates to
"Notify me but dont automatically download or install them". This should advise you if your computer tries to download WGA again.
Solution 3
For windows XP SP3 users try this method
1 Lauch RegEdit.
2 Browse to the following location:
3 Delete the folder 'WgaLogon' and all its contents
4 Reboot Windows XP.
Solution 4
Disabling and renaming the files 'WgaLogon.dll' and 'WgaTray.exe' in C:\WINDOWS\system32 folder by using the program Unlocker seems to get rid of all the nags/popups.
Solution 5
Another alternative suggest that three files are installed Windows XP System Folder for WGA:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dll
The wgatray.exe process makes the check for genuine windows software. If WgaLogon.dll is denied execution right, that WinLogon is unable to call it to check on Windows validity and display notification package at boot, and since WgaLogon is also responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change and disable the execute bit of WgaLogon.dll:
Turn off Simple File Sharing in Tools -> Folder Options -> View tab.
Right click WgaLogon.dll in Windows Explorer and open the Security Tab.
Click Advanced button.
Uncheck the Inherit box at the bottom.
Click the Copy button.
Click OK.
Go through each listed user/group and remove the "Read & Execute" permission for WgaLogon.dll, leaving the "Read" permission as-is.
Click OK to apply the permission changes.
Close the file properties dialog.
Restart the computer.
Turn "Use simple file sharing" on (optional).
Mar 07, 2011 | Nitro Soft Nitro CodecPack for Windows7
Admin password has changed somehow
Hi, man. Don’t worry, there are many people forget their admin password or lost it, and there is a popular solution for those who have been locked out by computer. For this solution, what you need is a second computer that can connect to Internet and then freely download Windows Password Recovery 6.0 at http://www.recoverlostpassword.com/products/windowspasswordrecoery.html With it, you can create a reset CD which can be used to reset Windows admin password without erasing anything.
Jan 23, 2010 | Toshiba Satellite M100 Notebook
Windows script host
My Documents Folder - Opens Upon Boot
To Stop Windows Explorer from opening My Documents: Check your settings here: Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
In the right pane under Userinit - Change the key that reads:
C:\Windows\System32\Userinit.exe,C:\Windows\System32\Userinit.exe
To:
And also here: Start/Run/Regedit
Start/Run/Regedit
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows. In the right pane, check your settings under Load.
try this rate the solution
Jul 06, 2009 | Computers & Internet
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Acer Aspire 5610-4648 Notebook Logo
693 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
