Question about LG Televison & Video
Calypso tv input - LG Televison & Video
How do I run channel auto scan on Calypso TV
try going to settings ,menu then hit present or auto scan
Oct 26, 2014 | Calypso 26"" LCD Hd TV
I have a calypso flat panel TV every time i switch it off and turnedit back on it comeson in AV mode with out me switching it from TV to AV,then i have to always go to the menue and put it bact into TV...
If you have something plugged in the AV, try unplugging that, and then switching on off etc tests. If that works and solves the problem, then the TV is sensing whatever is in the AV input, and thinks you want to use that first.
I'm not at all sure you can change this, except by making sure the thing in the AV input is either totally turned off, or unplugging it. I hope I'm wrong about this part, and if so it'll be clearly stated in the user guide some place about how to disable this auto-selection.
I hope this helps find the cause of your problem.
Dec 17, 2013 | Televison & Video
Calypso tv power cord
Info is too vague.
What model, size would be helpful. Does it use a power supply? Can you use a power inverter?
Nov 17, 2013 | Televison & Video
I have a Calypso tv and want to program it to my tv Satallite remote
http://www.calypsolcd.com/remote-control-codes.php
Dec 01, 2010 | Televison & Video
I have a new calypso tv & i want to program it to my motorola remote for my satelite rec.
Remote codes are here:
May 16, 2010 | Televison & Video
Whirlpool Calypso Problems
Make sure the outlet has power, if it does then you have a control board issue or possible wiring problem inspect/test control board input voltages
Sep 26, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Televison & Video Logo
Computer Repairing
Computer Repairing
