Question about Gigabyte 845pe (GA-8PE800PRO-R) Motherboard
Can't boot after upgrade bios f6
I have motherboard 8pe800p f5, after i upgrade with bios 8pe800p f6. my computer can't booting. please give me solution for my problem..
thank's a lot before...
  • 271 Answers
If you flashed the BIOS and it stopped for whatever reason or you flashed the wrong BIOS version, there is nothing that you can do except to replace the BIOS IC.
  • If the system has a boot block to restore the original BIOS, use it. Refer to your motherboard documentation.
  • If not, you will need to contact the system or motherboard manufacturer for a replacement.
Posted on Mar 12, 2009
How to configure BIOS to boot legacy USB or CD?
once in the bios go to boot options hit enter and choose the option you want then use your F5 and F6 keys to move it up or down to get it to the top.
Apr 29, 2014 | Lenovo Ideapad 3000-G510 , Y310, Y350,...
Change bios to boot from cd
press F2 key at startup and select boot tab. i think you use F5 and F6 keys to move your chosen boot device up or down. once you have the CD drive selected as 1st boot device, exit saving changes
Mar 11, 2012 | Acer Aspire 5735-6694 Notebook
I need to format my machine ,but i cannot go to the bios setting and cannt boot the OS cd from CD drive,, on which tab can i preess for see the bios setting?
Usually before OS boots you have to press either F2, F5,F9,F12
if neither one works try all F keys until you go to Boot selection or BIOS.
Have fun :)
Aug 17, 2011 | Mercury P4VM800M7 Motherboard
Recovery Issues A105-s361. Boot sequence always starts with HDD. Tried F12, tried F2 (bios). Any other way to boot from recovery disk(CD-ROM)!!
There is still a way for you to boot from your CD ROM. Just access or go to BIOS again, look for "BOOT" tab and then set the boot sequence of your computer and the set the first priority to be on the (ODD or CD DVD ROM), just make sure you put the CD ROM option at the first section and to do that, Use the arrow keys on your keyboard and highlight it and then press normally "F5 and F6" further instruction are there any way. Once your done, press F10 and select save and exit, Insert the disc on the CD ROM restart your computer at that time your computer should be booting now from the CD ROM.
Cheers . . .
Feb 09, 2011 | Toshiba Satellite A105 Notebook
I can't use any sata hardwewr on my motherboard
create a sata diskett[floppy] using your motherboard cd and press F6 when booting from xp cd this will install sata raid drivers for your motherboard
Jun 23, 2009 | ASUS P5RD1-VM Motherboard
System restore disk for HP compaq Presario 1700 help
hi, you may need to set your laptop to boot from the cd/dvd. you will need to enter the bios and check the boot priority. power the laptop as soon as you power on press either F2 or F10 to enter the bios (you have to be pretty quick with the F2 button). once in the bios look for the heading BOOT or BOOT PRIORITY F5 or F6 willchange the boot order.
hope this helps
Feb 22, 2009 | HP Compaq Presario 1700T Notebook
SL-86SPE-L Motherboard manual and / or bios jumper settings required.
Load fail safe defaults from CMOS/ deseabled the CMOS.
OR press F5 when booting & continue.
Feb 18, 2008 | Soltek SL-86SPE2 Motherboard
Gigabyte 845pe (GA-8PE800PRO-R) Motherboard Logo
125 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
