Question about Emulex NETQue Print Server
Cant change or remove the password.
How to get contact with the printer server. I don know the ip adress of the server. This problem was solved, but now i have a next problem. Well it worked out, but (theres alwayas a but). I resolved the ip adress and changed it to my network range with hyper terminal. If i type in the just assigned ip adress in my browser, i get the configuration tool (network printer manager) If i want to change something, it keeps on asking for a password (see jpg). I have administrator rights on the pc. I also did a "reset to factory default" with hyper terminal, but it seems to remember the password even after the reset to default. I cannot add a printer because of this problem. I hope to have a soon awnser again. Regards Erwin
    Problem Solver:
With some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Posted on Nov 29, 2008
At the Enter username enter any 2 characters
at the Server> prompt enter su
at the Password prompt enter system
Posted on Dec 05, 2007
  • 12,061 Answers
Well a lot of the time the password is admin like on my D-link it is Logon:admin Password:admin there is a site that has passwrds for everything so try here.... http://www.phenoelit-us.org/dpl/dpl.html Good luck
Posted on Aug 03, 2007
I'm using ricoh aficio 2045e, it's not printing! I think because I don't have the hostname or the ip address and I don't know from where to get it?
Enter in SP mode and print the ALL SMC report .In this report find the IP adress.Enter in your PC printer device the IP adress.
Feb 17, 2013 | Ricoh Aficio 2045e 2035e Copier...
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
I would like to scan a color picture and send it to my e-mail address. What are the exact steps to do this.
Type the machine ip adress on the adress bar of the machine and hit enter.
Then the machine webpage will appear
1. Click the Network Settings link, login asadmin, username is admin and password is also admin and click the Services Settings link.
2. Use the SMTP server IP addresses in the Primary andSecondary Server fields rather than the server names.
3. Verify if the mail server is using the default SMTP portof 25. If it is not, then change the Port Number to match the server. Port 587is a commonly used port if authentication is required.
4. The Reply Email Address must be a valid local emailaddress for some mail servers or messages will be discarded. If using a Reply Email Address like: noreply@whatever.comor scanner@whatever.com confirm that the email address actually exists.
5. If the server is running SSL (GMail uses SSL) for bettersecurity, check the box next to Enable SSL. Click here for instructions on how to setup scan to GMail.
6. Leave the User Name and Password blank temporarily andperform the Connection Test. A successful response will verify that the serveris really a valid SMTP mail server.
The following should be performed byan I.T. person
Mail server settings
1.Createa new user account and password for the mfp on the mail server this useraccount name , the name set in the mfp
Apr 08, 2011 | Sharp MX-2700N Color Copier
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Jan 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Dns error 80710102
Hey peterk18,
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type www.google.com in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
Greetings,
DarkNeogen
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
I need to change the channel on my router
Can you ping the ip address? By default, the ip address should be 192.168.0.1. You can verify by going to Start, Run, cmd. At the command prompt type ipconfig /all and you will see the ip address, dhcp server, gateway, etc. The gateway will be the address for the router. Type ping 192.168.0.1 (if that is the address). Also, the default username is admin and the password is left blank.
Nov 08, 2007 | D-Link DI 514 Wireless Router (DI-514)
Contact
The following link will tell you how to connect a serial cable & set the address: http://205.200.75.226/support/printer/emulex.html
Aug 02, 2007 | Emulex NETQue Print Server
Emulex NETQue Print Server Logo
651 people viewed this question
Top Emulex Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
