Question about Maytag MSD2758G Side by Side Refrigerator
Msd2641kew maytag refrigerator wil not dispense water or make ice. i don't know how to improve the water pressure to the fridge. but my water pressure in the house is fine. what can you tell me
I read some information on the internet, but I am female and kind of confused as to the information I read. this fridge is almost six years old and I had it repaired only once two years ago. I forgot what was wrong with it and it was still under warranty. I want to repair this myself and I know I can if someone could tell me how. I have not went so far as to detatch the water inlet valve, but I could if instructed. thank you again
    New Friend:
  • 19 Answers
Get an air hose and blow out the line, it may be getting stopped up.
Posted on Jul 04, 2017
the dr
  • 447 Answers
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
perhaps there is ice holding it in because that tab is all that holds it.
Posted on Sep 29, 2007
SOURCE: Maytag refrigerator Model MZD2766GEW
You need a new Adaptive Control - part number 61005988.
Posted on Sep 29, 2008
  • 19 Answers
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: water puddle under fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 28, 2008
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
How can we fix our Maytag Refrigerator's ice dispenser?
Start here http://www.partselect.com/ they have excellent manuals to get part numbers and a lot of times have videos to show you how to do your repair.
Hope this helps
Jan 19, 2015 | Maytag Matag 25.6 Cu Ft Side By Side...
Water and ice dispenser don't work
This is a pretty common problem...
Try unplugging the fridge for 30+ seconds. If the display doesn't light up after you plug it back in then the control board is dead. It's going to need to be replaced.
If you know the model # of your fridge you can search for a replacement part here:
http://www.searspartsdirect.com/partsdirect/index.action
Dec 31, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Maytag msd2556ae will not dispense water throught the door. It makes ice just fine, and will dispense ice through the door, but not water. I've replaced the filter in the fridge, but no change.
There could be a blockage of its iced up. A complete defrost might fix it.
you'll have to leave it switched off with the doors open for 24 hrs.
Sep 01, 2012 | Maytag Refrigerators
Fridge/freezer leaks water
This is not very common. If you get water coming out of the ICE maker when you press the WATER dispenser, then the thing I would check first is the solenoid controlled water valve. It might be sending water out both legs at the same time. BUT if you have had work done on it lately, I would suspect that someone didn't get the electrical leads onto the control board correctly.
Jan 15, 2012 | Maytag Refrigerators
Hi i have a double door samsung fridge and when i place dispensable ice on cube i still get crushed ice in addition is there any way to increase the speed at which water comes out the dispenser
There is likely a faulty solenoid which switches the ice dispenser between "crush" and "cube" mode.
The water pressure at the water dispenser is proportional to the supply line water pressure. Unless there is a restriction in the supply line or the dispenser line, the only way to increase the water flow is to increase the supply line water pressure -- not an easy proposition.
More info, let me know.
Charlie
Feb 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
Water button sticking
Replace that microswitch for the dispenser lever. It might not be a separate switch though, it may be part of the control board for the dispenser module. disconnect power to the fridge, remove the dispenser cover to expose the wiring, etc., determine what the lever actuates when depressed, and it will likely be the microswitch separate from the board.
Jul 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Nov 19, 2009 | Maytag ZigZagW / B Side by Side...
Water/ ice issue
this problem is either low water pressure or a faulty water inlet valve. if u have good pressure, change the valve. repairclinic.com
Jul 25, 2009 | Maytag 25.6 cu. ft. Side-By-Side...
Maytag MSD2758G Side by Side Refrigerator Logo
73 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
