Question about Garden
The bucket on my BX23 Kubota tractor will not lift up
The hydraulic pistons quickly lost the ability to raise the bucket.
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
SOURCE: hydraulic lift pump not lifting how to replace pump
I have a Ford 1700 and the first time this happened I assumed it needed the oil changed (DID NOT read the manual). After changing the hydraulic oil for about $50... it ran no better. Read the manual. Bought the hidden oil filter. Bought new oil. Problem solved. The filter on this tractor sits in the bottom of the rear end housing and collect ever piece of junk. Good! But a pain to change the filter.
Posted on Nov 24, 2009
  • 251 Answers
SOURCE: ALLIS CHALMERS 190 GAS -HYDRAULICS ON TRACTOR ARE
hi , replace your hydraulic oil filter and pump and renew the oil .
hope this helps
Posted on Jun 21, 2010
freetek
  • 5568 Answers
SOURCE: The hydraulic steel line on my 2010C bucket loader
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Posted on Sep 16, 2010
  • 135 Answers
SOURCE: The hydraulic pump does not shut off and the lift
Sounds like you have a hydraulic flow valve problem. Check the lift arms when the pump is running to see if you have any hydraulic fluid leaking there.
Posted on Nov 18, 2010
1640A Kubota tractor front end loader or bush hog will not lift
I would say you have air in the hydraulic system or you are low on Hydraulic fluid, I am not sure of the procedure on this make to bleed the air out but a dealer may help you if you ask nice.
Sep 22, 2016 | Cars & Trucks
Change bucket seals and bucket still seep down
Seals are gone in pump and allowing flow back into holding tank if it is not seeping onto the ground
Mar 03, 2016 | Cars & Trucks
Machine was switched off at end of shift and key handed in as per procedure. machine was found this morning with bucket in down position with front wheels raised.
You have a ghost! or someone playing a prank. or someone trying to nick it, started it, pressed the wrong lever and lost their bottle.
Most of these keys can be replicated with a screw driver or even a nail so they are not very secure.
Aug 13, 2015 | Bobcat Garden
Hydronic system pressurizing filter and leaking
There shouldn't be a lot of pressure at the filter. Try a new one.
Nov 28, 2013 | Computers & Internet
Kubota bx23
Insufficient information.
Do any lights come on?
Does the engine turn over?
Is it out of gas?
Nov 03, 2013 | Kubota Garden
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
Case IH DX29 Hydraulic prob. bucket wont lift
Check control cable from lever to valve to see if it has broken or seized
May 08, 2012 | Farmall Toys
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
