Question about Cell Phones
Can't use my LG Headset HBM-550 with my LG Phone TG800F
I'm able to turn both of them on ! And I followed all the instructions. But I can't pair them. The headset doesn't flicker in red and blue once I pressed pwr. It needs to do so, so the phone and the headset can pair.
Can you help ?
Thank you
    Novelist:
  • 113 Answers
With the device off, press and hold the power button. continue to hold the button after the blue light comes on and eventually it will flash blue and red. your headset is now in pairing mode. proceed to search for the device from your phone where you will select the device and enter 0000 as the pass code.
you should not have to do this again as long as you do not delete the device from your phones trusted device list.
Posted on Mar 12, 2009
How to reset lg hbm - 550 bluetooth headset,I lost have the pass code? i need your help ...! thanks
If you look in the manual in the link give by jeffsgirl903 it says "When asked for the Pass/PIN code during the pairing procedure,
please enter “0000” (4Zeros)."
Dec 08, 2009 | LG HBM-550 Wireless Headset
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
Sep 16, 2009 | LG HBM-550 Wireless Headset
I have a HBM-550 LG Bluetooth I am trying to pair it up with my samsung phone i already found it but when i enter the passcode 0000 is it incorrect , Am i doing something wrong .please help
Try 9999.Else the passcode has been changed earlier or the piece is malfunctioning.you did nothing wrong so far,since the headset is being detected.If the headset still does not pair with the phone,then have to check it with the vendor.Good luck,Please do post comments and results.
Apr 16, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
LG HBM 300 Bluetooth headset
Hey make sure your headset is in pairing mode before you search for it. You might have to hold the on/off button for 5 to 10 sec. Then your 0000 will work.
Aug 01, 2008 | LG HBM-550 Wireless Headset
HBM 550 pass pin 4 zeros doesn't work
Ok kids here you go.
First turn your blue tooth off. Now hold the on/off button for at least 5 seconds (this is very important. You must hold it till the light blinks blue and red.) Now on your phone search for the device. Select the HBM- 550 and put in your 0000.
You must have the headset in pairing mode first.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Your welcome.
Jul 24, 2008 | LG HBM-550 Wireless Headset
Passkey
The passkey is 0000
Dec 25, 2007 | LG HBM-550 Wireless Headset
To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Dec 08, 2007 | Nokia N95 Cellular Phone
LG HBM 550 with Chocolate
Here is the problem, what most of the people do with this LG HBM 550 is press the PWR/END button on the headsent and when the headset light turn on Blue they let the button go and try to pair the device, this is worng when light is flshing Blue only it is not in the pairing mode.
You need to press and hold the button on the head set for five second and when the light flicker red and blue alternately, now device is in the paring mode.
Using you phone when to pair this device it might ask, depending on you r phone setting for the PIN or pass code which will be "0000"
Try ,,good luck
Regards
Chinmay
Nov 22, 2007 | LG HBM-550 Wireless Headset
Cell Phones Logo
89 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
