Question about Garden
Manual for Craftsman Model #536796520 edger-trimmer
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
digritz
  • 530 Answers
SOURCE: this is on a trimmer edger model # 536.796536
You can get rebuild kits from just about any lawn mower/small engine repair shop around. However unless your trimmer has had harsh treatment it most likely only needs a good cleaning. They are pretty simply to disassemble.
Remove the carb from the motor and get a clean spot on a bench or work table. You will need some solvent to soak it in, lacquer thinner works great because it will take care of any gas that may have turned to varnish during storage.
Remove the bottom float bowl attached by the four screws. Inside you will see the float. It is held in place by a pin that can be pushed out. Be careful not to lose the small wire clip that holds the valve pin to the float. After you have the float and valve out let everything soak over night. Using a small screwdriver (cheap jewelers drivers work best) wrap a piece of scottch pad or fine steel wool around the end and twist it into th port where the valve was. If you have a compressor blow it out the other ports and holes or a can of brake clean if no compressor and reassemble. It's also a good idea to clean out the fuel tank.
This will take care of 80% of problems with small engines. Any other trouble is most likely an issue it being worn out.
Hope this helps.
Posted on Sep 28, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman Trimmer/Edger 4.0 HP Engine races...
Most likely, the mechanical governor is damaged inside the engine. If you have tools, a sense of adventure, and lots patience, this can be replaced for a modest cost in parts.
If not, take it to a reputable repair shop.
The governor replacement involves engine removal, opening the crankcase, lots of parts-cleaning, and attentive reassembly.
Would be happy to help you if you decide to tackle this repair.
Hope this helps.
Posted on Oct 04, 2009
rycgl
  • 1545 Answers
SOURCE: I have a Craftsman Edger/Trimmer
You have a malfunctioning float and/or needle valve in your carburetor. Disassembly, cleaning and possible replacement of parts will be required.
Posted on Apr 22, 2011
Craftsman Online Manuals
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/craftsman_product_list.html
You will need to pick Edgers or Trimmers and then your model number so just pick manual that works best.
May 22, 2013 | Garden
Cannot find manual for Craftsman Lawn Edger Model No.358.757551
I could not find any equipment by Craftsman under the model number given. Here is the manual to a "typical" Craftsman gas edger.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L9060260.pdf
Jun 08, 2011 | Craftsman Garden
How do I get more line to come out of my craftsman trimmer model 316.79190?
Maybe try going to : www.searspartsdirect.com and download your model specific user manual. They probably have detailed instructions in there on the operation of your string head.
Aug 25, 2010 | Craftsman 25cc Gas Line Trimmer
Need parts for craftsman edger/trimmer 275.796432
Mar 21, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
