Question about Ekornes Stressless Recliner Chair Personal Computer Table
Ekornes PC table does not hinge with ease. How do I make it swing more freely?
My table does not hinge smoothly. How do I make it swing more freely?
Do i have to purchase new door hinges to change the swing of the doors or will exiting hinges work to make the change???
never saw duel swing hinges . righties swing right lefties swing left , so I would say YES you need to buy the other ones
Jul 27, 2015 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Trying to reverse door swing on Samsung washer WF405ATPASU/AA
Tony, this is a simple procedure and you just need a medium sized phillips head screwdriver. Start by opening the door and removing the two phillips screws that attach the hinge to the machine. Remove the door by lifting up and out. Next, remove the two screws that that you will now see (previously hidden under the door hinge that you just removed). Now, go to the opposite side and remove the two screws that hold the door latch and pull out the plastic latch insert. Also, remove the two screws located (about 4 inches) above and below the latch insert. Now simply reverse the process by securing the plastic latch on the left side along with the two screws (top and bottom). Before securing the door on the right side, lay it down and remove the screw that is used to hang the door (within a slotted hole on the machine) and move it to the top of the hinge (you will see a hole for it). Now simply hang the door on the right side of the machine, and firmly secure it with the remaining two screws. Your door should move freely and latch securely.
Dec 16, 2013 | Samsung Washing Machines
Hinge on extending table
Your table is not a laptop computer.
May 20, 2013 | Computers & Internet
My excavator hitachi ex200-1 weak swing and when you swing then stop vibration begin on turn table when i stop to swing,and when i swing and lift cylinder raise,vibration on the turn table will contin
Not sure would need to have a good look ,but i suspect a safety valve isnt closing properly causing thumping within the hydraulic system which is the vibration you can feel,shouldnt cost a lot to repair providing the faulty valve can be located so return to the dealer as they will have a good idea as yours isnt the first to go wrong iam sure
Sep 24, 2012 | Cars & Trucks
My 1997 Jeep Grand Cheroke's doors close funny. Both of them don't close smoothly. Anyone else have this problem? It's not when the door latches it's during the close, like something is bent but it's on...
Each door has two hinges. The bottom hinge has a lever spring and two rollers attached that prevents the door from swinging freely when it is opened or closed. (one roller for opening and one for closing) If the door seems like its bent, it is probably because the rollers are frozen and when you open/close the door the lever spring is scraping across the raised edges of the rollers instead of riding them. If the door is not moving smoothly, or is making loud creaking noises, give a good dose of WD-40 to the hinges as well as the rollers, especially the rollers. The rollers should roll when the lever spring engages it as you open/close the door.
Dec 20, 2009 | 1997 Jeep Grand Cherokee
I have a 2004 Accord and the passenger door swings open and closed very freely. It does not catch even on a level surface and the door will swing closed.
the "door check" is either broken or disconnected, compare it with the left door and check that strap between the hinges.
Oct 04, 2009 | 2003 Honda Accord
Table creation via textfields using swings
import java.lang.Object;
import javax.swing.table.DefaultTableModel;
public class tabletest extends javax.swing.JFrame {
String[][] row = null;
String[] title=new String[3];
private int i;
/** Creates new form tabletest */
public tabletest() {
initComponents();
setTitle("table test");
setVisible(true);
System.out.print("NO Database Needed");
title[0]="Name";
title[1]="Desig";
title[2]="id";
" In middle of this two source one generated code will be there that will be done by dragging ur fields to ur frame. THIS IS FOR netbeans IDE "
private void b1ActionPerformed(java.awt.event.ActionEvent evt) {
row=new String[4][3];
// TODO add your handling code here:
String s1=t1.getText();
System.out.println(" event 1");
String s2=t2.getText();
System.out.println(" event 2");
int k=Integer.parseInt(t3.getText());
String s3=""+k;
System.out.println(" event 3");
try{
// for(int i=0;i<=2;i++)
row[i][0]=s1;
row[i][1]=s2;
row[i][2]=s3;
i++;
}catch(Exception e){
e.printStackTrace();
table.setModel(new DefaultTableModel(row,title));
private void b2ActionPerformed(java.awt.event.ActionEvent evt) {
t1.setText("");
t2.setText("");
t3.setText("");
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new tabletest().setVisible(true);
// Variables declaration - do not modify
private javax.swing.JButton b1;
private javax.swing.JButton b2;
private javax.swing.JLabel jLabel1;
private javax.swing.JLabel jLabel2;
private javax.swing.JPanel jPanel1;
private javax.swing.JLabel l1;
private javax.swing.JLabel l2;
private javax.swing.JLabel l3;
private javax.swing.JPanel p2;
private javax.swing.JScrollPane scp1;
private javax.swing.JTextField t1;
private javax.swing.JTextField t2;
private javax.swing.JTextField t3;
private javax.swing.JTable table;
// End of variables declaration
Mar 13, 2009 | Computers & Internet
Ekornes Stressless Recliner Chair Personal Computer Table Logo
87 people viewed this question
Top Ekornes Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Ekornes Furniture Expert? Answer questions, earn points and help others
