Question about Pool & Spa
My pool light won't stop the strobe cycle. - Pool & Spa
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: My Hayward Colorlogic pool light is flashing like a strobe light.
That particular swimming pool light has a power-cycle feature that allows you to change the way your light illuminates your pool simply by turning it off and on. A strobe like effect is one of these power cycles. To change it, simply turn the switch off and then turn it back on within 10 seconds. It should reset to another cycle. It is is left off over 60 seconds, it resets to the first cycle, which could be the strobe. If cycling doesn't solve the problem, your bulb has probably malfunctioned and you are going to have to have a repair tech service it.
Posted on Jul 14, 2010
My jandy pool lights are not in sync color-wise, and one flashes like a strobe light. how do I reset it?
go into system setup to lights pick yours enter and turn aqualink off then back on they should work
Jul 10, 2014 | Jandy Pool & Spa
My lights are out of sync color-wise, and one flashes like a strobe light. How do I reset them?
make sure to go into system set up and enter the lights you have turn off lights then they should sync if not shut aqualink off then back on
Pentair pool light fiber optic won't light:
check light generator on deck light probably burned out
Jun 14, 2011 | Pentair Pool & Spa
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
My hayward colorlogic pool light flashed like a strobe light. After repeatedly turning it off and then on again, it now will flash light for less than a second and then turns off. Spa colorlogic works...
You should check your ground fault and reset if necessary. This particular swimming pool light should cycle through a variety of different light shows by turning the switch on and then off for no more than 10 seconds. If it is not cycling properly, you might be leaving the swith off for longer than 10 seconds or your bulb might have malfunctioned.
Jun 28, 2009 | Hayward 12v LED Color Logic Pool Light...
Jun 16, 2009 | Hayward 12v LED Color Logic Pool Light...
FD-95, F-stops & Strobes?
You might try adding an external view finder that is close to the FD-95 picture size. A lot of old cameras have them and it could also be used for sports as well, it could be added with Velcro or some other type of mounting. I am working on this problem myself. Good luck
Sep 11, 2005 | Sony Mavica MVC-FD95 Digital Camera
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
