Question about Whirlpool WRF560SEYM 30" French Door Refrigerator with Exterior Dispen
How can i take off the drip pan for a whirlpool wrf560seym refridgerator
3 Suggested Answers
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
  • 159 Answers
SOURCE: when freezer defrosts the water goes into the
just under the evaporator is a hole where the water runs normally that pipe gets blocked
Posted on Jun 17, 2009
Water leaks
Need more information
Does the refridgerator have plumbing for water/ ice? Is the water connected? Check that fittings are tight and not leaking.
How old is your machine? Older refridgerator have a drip pan in order to be frost free. Drip pan could be not in correctly or the hose from compressor is not flowing to drip pan.
Is the refridge level?
Oct 15, 2015 | Whirlpool Refrigerators
Water is dripping inside refridgerator coming from inside back center. Why? Sometimes it drips, sometimes it runs and sometimes it's fine.
Is water connected to this unit for the ice maker? If not than this would be the water that comes off the refrigeration coils as the unit defrosts. The water should be collected by a shallow plastic collector, routed to a drain tube, and empties to a pan under the frig where the water will evaporate quickly. Check drain collector for damage and drain hose for blockage.
Mar 31, 2010 | Whirlpool Refrigerators
Water dripping sound coming from new refridgerator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan. This is the only source of water if nothing else is connected. Are you seeing and water anywhere.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is dripping from the freezer into the refridgerator
your freezer cabinet need to get all out also the ice machine(if you got one),and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday.com
Jan 03, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
Refridgerator drips water from the cold air vent.
if your freezer is on top,you most likely have an overflowing defrost drain. there is a drain that starts in the freezer and continues down to the drip pan. start at the top and work your way down.
Jul 26, 2009 | Whirlpool ET4WSKXS Top Freezer...
I AM TRYING TO LOCATE THE DRIP PAN UNDER MY MAYTAG REFRIDGERATOR MFD 2561HES
now days a lot of drip pans are bolted in under the compressor. you can't remove them without a lot of work.
Jul 26, 2009 | Maytag Refrigerators
When freezer defrosts the water goes into the refridgerator instead of under to the drip pan
Jun 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Whirlpool WRF560SEYM 30" French Door Refrigerator with Exterior Dispen Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
