Question about Hitachi DZ-HS300A DVD Camcorder
ImageMixer 3 SE for SD. Can't Create Disc, Save Files to PC
ImageMixer 3 SE for SD. Create Disc, Save Files to PC & Write Back To Camcorder options all greyed out, can only Browse & Authoring & Exit. User guide was supposed to by attached as a pdf but that isn't there either. I've downloaded latest version from Pixela website and the damn thing still isn't working - any ideas? I only want to create a disc?
  • 6 more comments
  • Anonymous Mar 20, 2009
    Hey Samfell,
    I have the same problem...I consider myself pretty good on the computer, but like you...I am just not getting this "Imagemixer 3." I am having trouble editing??? I also did not receive a manual with my camcorder......
    If you have found a solution...please report back to me....
    Thanks
    Sweet Pea
  • spribb Mar 21, 2009
    I Have the same problem!! Someone lease help us!
  • nyny23 Mar 22, 2009
    I have the same freaking problem!!!!!!
  • Anonymous Mar 26, 2009
    I have the same problem. It worked fine on my laptop, but then my laptop died, and I tried it on my NEWER desktop, and it didn't work.
  • Anonymous Mar 28, 2009
    same as you.
    any help?
  • digidog Apr 05, 2009
    I have the same problem. I am able to transfer video from my Canon HG20 easily enough, but the format m2ts is not supported by Windows Media. I can't select "creat disc" in the menu... wtf? What video softwre are people using, because ImageMixer sucks...
  • Den09 Apr 13, 2009
    Me, too. Quite a club we have going.
  • Anonymous Apr 17, 2009
    You don't need a mac, you need Canon to use a regular harddrive technology to allow you to download files to your pc. Not some software that doesn't work.
This has to be the shittest software ever! I've edited my clips in the editing mode but can't do anything but save it as a working edit. The file format is useless for anything but this program so all you can do is edit to your hearts content and then edit some more. Complete waste of time. I tried connecting the camera (Canon HF10) and that took away all editing options. Could only burn straight to DVD or upload to computer. For such an expensive camera this is very disappointing.
Posted on Jun 02, 2009
My issue was that I couldn't find the option of 'pc'. With the camcorder plugged in, the power on, and the USB connected I found I was able to get to the menu once I pressed the camera/play button on the bottom of the LCD screen. Once I pressed that I had the option of playback on the computer. I selected that and the Pixela application started up and I was able to access the 3 buttons that were previously grayed out. Good luck!
Posted on Sep 30, 2009
1 set the mode dial to camera ( this is the little logo you set when you want to see your video on the camera it is on the back of the camera) on the canon it is the blue camera logo
2 Plug the camera on the wall ( not on the battery)
3 Plug the usb cable to the pc
4 On the camera screen choose PC/Printer with the joystick
5 press on the joystick to accept the selection
6 open pixella
7 the option transfer fro pc is available click on it
8 wait for pc to read memory card
9 chose destination for saving ( param/ pref)
10 click save
11 click execute
12 open your destination file and you will see the video being transfered.
P.S. I am french speaking so the name of the function choice may be a litlle different because I try to translate those as accurately as I could
Zenmarc
connect your cam to usb
Posted on Feb 07, 2010
  • 3 Answers
Make sure the usb cable is connected to the usb port on the back of the computer. Imagemixer will then open and all icons will be functional.
Posted on Dec 26, 2009
Make sure the camcorder is not set to the photo mode. Make sure it is set to video mode, before selecting PC Connection type. Then when you load the software the options will no longer be greyed out. Now if I could just figure out how to get video I've moved around and reorganized to show up in the list to be moved back to the camera?
Posted on Jul 23, 2009
This is a lame design but unless you connect the camcorder to the computer those options will not be enabled.
This is given in the FAQs.
http://www.pixela.co.jp/oem/canon/e/imagemixer3_se_canon/qa.html
Setup - There is a menu not selectable in [ImageMixer™ 3 Launcher].Following menu items cannot be selected when the camcorder is not connected.
- [Create Disc]
- [Save Computer]
- [Write Back to Camcorder]
Posted on Apr 28, 2009
Solution #7 worked for me. I can't believe it, but when I plugged the USB cable into the back of my computer all the ImageMixer icons became available and I could finally copy. The SD card reader must be different in the front of my PC vs. the back. Weird. I never had this problem with my Panasonic, and it used the exact same card.
Posted on Jan 03, 2010
I never expected canon would supply such idiotic software. It combines files before creating a disc. Does anybody know how to write a disc without combining files? Is there any option in the ImageMixer 3 SE software to disable combining files? Worst part is, they dont even supply proper help files or instruction files. I wish i had bought some cheaper camera now instead of canon.
Posted on Mar 05, 2010
I have the same problem with canon hf 11,i connect everything,the menus appear on the screen,i started to write dvd-video not avhcd becouse i don't have blueray to play but after the following message apear: "combine movie file" the softeare do nothing and don't write on dvd-r
Posted on Dec 28, 2009
Make sure you have these things done before importing:
1 - Camera power on
2 - USB Cable plugged into the Camera and the Computer
3 - POWER CABLE plugged into the camera and an outlet (IT WONT LET YOU CAPTURE OTHERWISE)
4 - Select the "Computer" setting after the camera is plugged into the computer.
Good Luck Everyone! AND GET A MAC!!! Everything is 1000 times easier on the Apple systems! PC Will give you head ache after head ache until your head will explode and your only cure will be a mac!!!!!
: ) Happy editing... it'd be easier on a mac.
-Jonah (PC User for over 12 years, Mac use 1 year. Once you go mac, you never go back.)
Posted on Apr 13, 2009
Solution:
download 'Video Convertor for Mac' from http://www.applemacvideo.com/mac-video-converter.html
There is a trail version which places a watermark on the video, but you can upgrade to the full program for $39 excl. tax
Posted on Jan 17, 2011
  • cedlong Jan 17, 2011
    Hope this helps.
A bit easier solution what worked with the ImageMixer3 1.0.1.15: when you have finished editing then select all thumb pictures and go to save panel where you can use the save button. This allows you save your edited material as m2ts-file. You can author a disk by importing this file to either DVD or AVCHD list and press write button.
Posted on Dec 23, 2009
Solution #5 by jtyrkalo WORKED !: 1. PLUG AC ADAPTER INTO CAMERA. 2. PLUG USB INTO CAMERA AND COMPUTER. 3. TURN CAMERA POWER ON. 4. OPEN LCD AND LOOK FOR BUTTON INDICATING CAMERA<=>COMPUTER, HIT IT. 5. OPEN UP IMAGE MIXER 3 SE, ALL MENU OPTIONS SHOULD NOW BE AVAILABLE. Jonahpauline above is right, I'm gonna start saving for a MAC !!!!!!!
Posted on Nov 04, 2009
  • scottfromsco Jan 03, 2011
    Camcorder must be set to movie mode on dial, not picture mode.
2 Suggested Answers
SOURCE:
SOURCE: ImageMixer 3 SE for SD. Create Disc, Save Files to
They are greyed out when the camcorder is not plugged into the computer, and a power outlet. Try that.
Posted on May 02, 2010
Unable to transfer videos from Canon FS300 to my pc or network drive
MOI is a computer file format used primarily to represent information. MOI files are associated with MOD or TOD files whose content they represent. The Pixela ImageMixer Video Editing Software should allow you to save your videos to your hard drive. But you may need to install the latest version of Quicktime Player (free) to view the the .mov files as an alternative to the ImageMixer program's viewer. Source(s): http://www.apple.com/quicktime/download/
Apr 11, 2011 | Canon VIXIA FS300 Flash Media Camcorder
ImageMixer 3 SE software freeze on adding new files to library
Are you running klite? Haali media splitter is incompatible with ImageMixer.
Go to Klite Config Manage Spliiters and turn Haali off for anything with TS in it.
Jan 10, 2010 | Canon Cameras
Last year in November ? December my son bought a camcorder CANON HF 11, supplied with ImageMixer 3 SE Ver.3,(on CD ) Ver.3.1., which was installed on a laptop ACER Aspire (Windows XP) and worked properly...
Hit your windows button on bottom left of your desktop screen go to search and type in search box .vid or .mp4 or if you know file names type it in search box, let me know what you find
Nov 23, 2009 | Canon Video Cameras
I have a Canon FS100 camcorder. The software is ImageMixer 3 SE for SD. I can play movies fine when the data is on the SD chip in the camera. When I save the files to PC then try to replay the mpeg videos...
Please download KLM-CODEC Pack from codecguide.com and this sould solve your problem
Please leave me feedback for the chat session we had sir,
Thanks
RNJ VINOD KUMAR
Sep 15, 2009 | Cameras
Canon FS11 cannot transfer pictures on to my Mac G4
I, purchased canon FS 10 CAMCORDER. With that Pixla Imagemixer 3 SE for sd the dealer has given. But it has no CD no. Can any one help.
Feb 01, 2009 | Canon FS11 Flash Media Camcorder
Panasonic VDR-D250 - I want to transfer the video taken on the 4" disc to usable DVD probably via pc - help please
Pinnacle Studio will work with your camcorder. You can either plug the camcorder into the computer and capture the video to your hard drive or you can import the DVD into the hard drive.
Looks like Imagemixer isn't available anymore according to a Google search.
Jul 27, 2008 | Panasonic VDR-D250 DVD Camcorder
Sound Recording problem
Don't know if your problem exactly like mine, but playing back recordings in the camera always have weak sound. However when editing the clips using Imagemixer 3 on your computer, the sound is louder and you can boost it even further with the "Adjust Volume" function of Imagemixer.
Bernie
Sep 01, 2007 | Panasonic SDR-H200 Camcorder
Hitachi DZ-HS300A DVD Camcorder Logo
11,349 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
