Question about Behringer Music
Need Behringer V-Amp Pro repaired or find diagram & parts
Need Behringer V-Amp Pro (model LX1-PRO) repaired or find diagram and parts list and source to buy parts (plug in connectors broken).
Thanks,
Bob
My euro2442 is not prperli runing so plese send me your service center in india
Posted on Jan 04, 2011
No sound and its haming
If you mean humming, then that usually points to a power supply problem.
Jan 20, 2016 | Behringer Lx1x X Vamp Amp Multieffects...
Eurolive B115D Powered PA Speaker
I would guess this is less than 3 years old and assuming you registered you will have a 3 year warranty so they'll probably fix it for you FOC
Jan 07, 2014 | Behringer Eurolive B115D Powered PA...
How to hook up my Behringer V-amp pro
Hook it up to what? You'll probably want it in the insert on the guitar channel.
Nov 30, 2013 | Behringer V Amp Pro Guitar Multi Effects...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
Direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Apr 12, 2012 | Behringer Ultrabass Bxl450 45w 1x10" Bass...
How o u hook up behringer feedback destroyer to a powered mixer
In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Feb 02, 2011 | Behringer Dsp1124p Feedback Destroyer Pro...
My mic input socket is broken do you have the part
The XLR mic connector is a board mounted part... You will not like the effort to replace it as most of the hardware must be removed from the panel to allow the circuit board to be removed so you can swap the XLR connector. Getting parts from Behringer is time consuming... but may be the only way to insure getting compatible one. Call Behringer to get their part number at 1-425-672-0816
The order from Full Compass... expect it to take a couple months as their repair parts chain is really slow now.
Jan 11, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I need a wiring diagram for the main circuit board in a behringer djx700 mixer
Behringer only gives schematics to their authorized service people.
I find I can usually trace stuff out as needed as the mixers are a very symetrical repeating circuitry.
Most components are readily available from other sources.
Aug 26, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Music Logo
1,102 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
