Amana 1 ton Residential AC / Outside unit comes on for a sec
Outside fan comes on for a sec then shuts off while fan inside house is still running. Checked Breakers. Set thermostat to lower cooling temp to no avail. Thermostat says that it is cooling.
Amana 1 ton AC unit
  • 2 more comments
  • rbarrett969 Mar 12, 2009
    Thank you!!!
    I have an Amana model # RCC60A2B and I am trying to find a replacement parts list or the proper part numbers for the run capacitor and the outside fan motor. Can anyone help me with this?
    The label on the run capacitor is:
    Mars
    55 +5. ouf +-6% 440 VAC 50/60HZ
    40 / 070 / 21 P2SH 0536B 70 C
    3285505H44P37NSX 12292
    It has 3 sections on the top for electrical leads and it is about 4 inches tall and round.
    Can someone help with the specs for the run capacitor and the fan motor?
    Bought the part(s) at Grainger. Model # 2MEK4 and 2GU40. I still want to replace a few more older parts like the fan motor. Any suggestions for the RCC60A2B Amana?
    Thanks for everyone's help with this matter. Trying to rate everyone.
  • 478 Answers
Open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Posted on Mar 12, 2009
  • mark milligan
    mark milligan Mar 12, 2009
    I would just get the cap ,unless you know fan is bad, any ac supply house will have replcement parts probly stated as a 1/4 hp reversable 230volt condenser fan motor and the cap jusr 55/5/440-470any thing above the 230v
  • 400 Answers
The outdoor fan is controlled by pressure. If the pressure is too low, it will not come on. This can be as a result of too little refrigerant or low ambient temperature. Another reason is that the fanmotor capacitor is bad. Hope this sorts your problem. ratemeplease.
  • 3 Answers
Sounds like you have a bad run capacitor or bad fan motor
  • meatyryon Mar 12, 2009
    you have a duel capacitor, the 440 means it is a heavey duty cap,
    you dont have to match the part number,the 55-5 is the rating for the compressor and fan motor, on the top of the cap is three connections they should be mark as comp one and fan on the other these are the two outside connectors the center is the power
    reconnect the replacement the sameway.you can get the capacitor
    at any supply house.but make sure the ratings are the same.
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
How may capacitors are there in LG split ac 1.5 ton unit
At least 3. 1 on the inside unit fan, 1 on the outside unit fan and 1 on the compressor. The outside unit may have both in a single chassis.
Aug 15, 2016 | LG Electronic Window Air Conditioner
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
3 ton air conditioner {1 yr. old } has rattle
check tightness of grill on outside of condenser,then push on different areas of the unit to see if sound changes or quits,also check all screws etc. & make sure they're all tight,is so it could be fan condenser motor bearings bad fan loose on shaft
Aug 27, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Heating & Cooling Logo
596 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
