Bowtie effect I have read online in many places about different things that have been done to fix this but can't find a place where it explains what has to be done.
  • 76 Answers
Convergance replace STKs
Posted on Mar 13, 2009
We have took our 2000 Honda Civic to three different places to have it inspected and some things come back some back "not complete". What should we do? Because its the only car we own and we have...
Contact your Local Trading Standards Department,at the Town or City Hall. Explain the 3 occassions circumstances, of the problem, and result. They will assist you, with any complaint that
you may have with any Licensed trader, about failing to meet the customer requirement for which
you may have been made to pay for.
Regards, DT.
Apr 26, 2011 | 2000 Honda Civic
I cannot run any CDs or DVDs on my Acer Aspire 5742Z-4097 laptop. The drive opens, however, it does not detect any disks, nor will the disk automatically start.
These are typical symptoms of the drive itself having failed. Usually it starts off not wanting to burn dvd's then not wanting to read them. It can still read cd's at this point but eventually has problems with these as well. You may have seen errors or a lot of activity that also took longer to do the same thing and so on.
What happens is the drives read/write head gets out of alignment over time. DVD's need the most accuracy and fail first while the cd's are much more tolerant.
Unfortunately the only fix is replacement of the drive. The cost of the drive from a online laptop or parts place will be $50-$100. This is definitely something you can fix. You need to remove ONE screw, pull the drive out, and put the new one in and put that screw back in. The drive just pops in. Probably took longer to type this than it does to change the drive ;-]
Have a look online for the drive and keep an eye out for instructions on replacing it so you can see if you are comfortable doing it. Most places will have a pictorial guide and some have online videos. It really is simple so you can do it. If you do a search for laptop repair parts you will find several web sites. Just look for your model to find your drive. If you aren't find the contact button and email them. Most places are quite happy to help. Some places will have used drives while other will offer new parts for about the same price.
Jan 24, 2011 | Acer Aspire 5742Z-4200 Notebook
Rear Projection - Color convergence/bowtie effect
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 04, 2010 | RCA HD56W66 56" HDTV
RCA HD52W69D with a slight convergence & bowtie problem
Ur convergence it dead.If can't auto adjust must replaced.Tries Tv repair World.com,Tv repair kits.
Nov 04, 2009 | RCA HD52W59 HDTV Projection Television
I was taking my steering wheel off of my 1997 honda prelude and putting and after market one on. and whil i was hammering the new one on the anti-theft starting beeping. and i read online about the "The...
With something like anti theft I would have to contact honda and explain what is happening if you cant find anything on line. Something like the anti theft thing is very particular.
Aug 17, 2009 | 1997 Honda Prelude
Samsung hcn5527w convergance factory reset
Sorry, I just saw this post.
I hope this helps.
Yes there is one more step. You should call the technician out and have them set up the Magic Focus adjustments. I have serviced these televisions for years and I have made this mistake and had to return to fix it. You should not have to pay for a rework. The technician should have done the complete job the first time.
I hope this helps
and good luck.
asnowman
Mar 19, 2009 | Samsung HCN5527W 55" Rear Projection...
Arched or bowtie effect
You have bad convergence Ics they are mitsubishi part # 267P150010 Generic part is STK 392-570 and they are at locations Ic8c01 and Ic8co2 on the deflection board. If you can solder you can take these out replace them and fix your problem for about 100 dollars. Best of luck
Josh
Feb 08, 2008 | Mitsubishi WS-65819 TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
