Question about Samsung Televison & Video
Samsung remote model #ah59-0233a not working - Samsung Televison & Video
Will a Samsung AA59-00482A remote work with my Samsung PN50C450B1D plasma TV?
all samsung remotes work for each other only diffrence some keys on remote may not there but for menu and vol channel all function works once its a tv remote
Apr 28, 2014 | Samsung Televison & Video
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung Remote won't work with Samsung HT System. BN59-00599A
My name is Gary and I work for Bogue Engineering Group and we sell many universal remotes for Samsung HT systems and they only cost $20. Please check us out at www.BogueEngineering.com or email me at bogue-engineering@live.com
Remote controls from Samsung are usually not worth fixing because it would cost too much to fix and you can buy a new or used one cheaper. Hope this helps.
Thanks, Gary
Jan 28, 2009 | Samsung BN59-00599A Remote Control
Remote tv control
The model number you gave isn't recognized by either Samsung at their download center and remotes.com sells the remote, they also do not have a part number on the 'Original Codes' page that even resembles that part number:
http://remotes.com/remotes/servlet/rs?a=Display&contents=codes_original&uuid=12220919936470
Since codes are so model and brand specific, unless you find the user guide on line, your chances are slim. Study the remote to see if it may have a built-in scan feature that allows you to step through every available code to find one that works.
Sep 22, 2008 | Samsung Remote Control
Sky remote tune to samsung
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Where can I find remote for Samsung tv model CT3361V
I have bought a Chunghop Rm-139e universal remote on Ebay that works for a Samsung Hitron
Jun 20, 2008 | Samsung TV Remote Control
Samsung plasma tv
Samsung codes for sky reomte 0060 065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
Jan 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Televison & Video Logo
212 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
