Question about Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White
Need manual for K-15Pr300SS intermatic timer - Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White
I have losts my manual to my ss7 intermatic timer. please help to reprogram.
Copy following link to identify timer and download possible manual from SS series Intermatic timers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add a comment as needed
May 31, 2013 | Intermatic Hardware & Accessories
Manual for intermatic timer part no. 2T511GA
2T511GA is an Intermatic enclosure (or box)
2T511GA is a grey standard Indoor/Outdoor Nema3R metal enclosure.
http://waterheatertimer.org/pdf/Intermatic-Enclosures.pdf
Any intermatic box timer will fit into the enclosure.
Tork makes the IAP adapter so Tork/ GE timers will also fit into same enclosure.
This includes digital timer and analog timers made by both companies.
To find the exact manual, add a comment and describe the timer and number of terminals, and what voltage is being used, and what you are controlling with the timer. For example 6 screw terminals A 1 2 3 4 and controlling 2-speed 240 pool pump. etc.
Also copy following link to identify timer and download manual:
Aug 16, 2012 | Intermatic Hardware & Accessories
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
I need instructions on how to program the timer. Can you sent via e-mailm a copy of the instructions? Thank you.
You posted under Intermatic HB88RC 6 button timer:
Add a comment any time.
Manual for HB88RC
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
If your timer is different, check timers on link below to identify your timer.
Each timer on page has manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
geno_3245_165.jpg 6 button 7-day
Dec 10, 2010 | Intermatic HB88RC - 7-Day Programmable...
I need the instruction manual for Model # R8806R101C.
Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
R8806R101C manual is not shown on Intermatic, even among discontinued models.
But product is still for sale.
R8806P manual is available:
I suspect manual is very similar since it's a mechanical time piece. If not, then add a comment with specifics and I will help.
120V:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8815p101c%20-%20english.ashx
240V
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
R88 series sprinkler timers: click model number to see manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Nov 22, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I NEED A PROGRAMING MANUAL FOR AN INTERMATIC TIMER, MODEL # ET70415CR
Here are all the ET7000 series manuals
Click product number and drop-down shows manual
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Here is the ET70415CR manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70415cr%20-%20english.ashx
This timer can be used for 120Volt or 208/240/277Volt circuits
The important thing is to install the 'voltage selector jumper' BEFORE connecting power
The jumper is supplied with timer
Oct 2010
If you need more help with specific parts of the manual, add a comment and I will respond
Oct 27, 2010 | Intermatic ET70415CR Electronic Energy...
Need a copy of manual
You can get the manual on the link below.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 25, 2010 | Intermatic ET8215C- 7-Day Electronic...
Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White Logo
49 people viewed this question
Top Kichler Hardware & Accessories Experts
Scott Jelt
Scott Jelt
Gene Haynes
Tom Chichester
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
