Question about Ngk Electrical Supplies
Lamp timer wiring diagram - Ngk Electrical Supplies
I need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
Wiring diagram for Omron off delay timer
Which Omron timer?
The model and wiring diagram appear on side of timer.
Add a comment with more details and I can track down the information.
http://waterheatertimer.org/How-to-wire-pin-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#Omron
Sep 07, 2012 | Amperite Dayton Solid State Timer On Delay...
I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
Link below has wiring diagrams and wiring manuals for 240V 8145-20
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
Need connection diagram Thks
The following diagram is for timers with green, black, white, and red wires:
If your timer is different, add a comment with model number.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Here's what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push manual override button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Woods 59007 Decora Style 3015105 Minute...
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
How do i wire a Paragon 4001-00 timer?
Link below has wiring diagrams for 4001-00 timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Manual with wiring diagram:
4001-00 is wiring diagram #1
There are 3 terminals 1 2 3
Black Hot wire from circuit breaker goes to terminal 1
Black wire to Load (light, fan, motor) goes to terminal 2
Whites wires connect to terminal 3
Aug 13, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
How to connect a lampost to a timer. GE Time Switches 15207
This timer has a lot of capability that you don't need, so you have to do a couple of things. I will assume that you are using this switch at 120V and simply want it to turn the light on and off. See page two of the drawing at this link: http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15087-15207-56922-Manual-eng.pdf (this should be the same as the instruction sheet that came with your switch if you bought it new)
First, be sure to set the DIP switches according to the instructions for 120V (all 4 switches "ON").
For your wiring, refer to the first diagram on that page labeled "Timer and Load, Same Voltage, Wired as Single Throw". The two arrows on the left are the wires from your circuit breaker. The two arrows to the right are the wires going to the lamp post. The top one is black and the bottom is white. With that in mind, you will connect both white wires to the TIMER2 terminal. You will connect the black wire coming from the breaker to the TIMER1 terminal. You will also have to add a jumper wire from the TIMER1 terminal to the COM terminal. Your black wire going to the lamp post should be connected to the NO terminal (that means Normally Open, the other one is Normally Closed.)
This should get you there. Let me know if you have other questions. Be safe, good luck, and thanks for using FixYa. Please vote is this was helpful.
Al K
Mar 26, 2010 | Electrical Supplies
Electrical Supplies Logo
95 people viewed this question
Top Ngk Electrical Supplies Experts
Steve
Gene Haynes
Are you a Ngk Electrical Supply Expert? Answer questions, earn points and help others
