Question about LG WT4870CW 4.5 Cu. Ft. Top Load White Washer
WT4870CW stops after each cycle - LG WT4870CW 4.5 Cu. Ft. Top Load White Washer
WT4870CW this washer keeps draining no matter what cycle you put it on... why does it continue to drain
Your wash machine may have a water level sensor. If the sensor does not feel the pressure build in the water line; your machine will not fill. Research to find out if your particular machine has a water level sensor.
Oct 13, 2017 | Washing Machines
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
E6 error will not wa what is an e6 error Lg top loader
Check out this website as it may help you.
The Fault has something to do the drive system of the washer. Different model however should be the same. LG WT4870CW error code E6 The Laundry Appliance Repair Forum
Nov 15, 2015 | LG WT5101H Top Load Washer
Deposits small bits of dark, greasy crud on laundry.
This often indicates a seal has failed and the lubrication of a bearing is being released into the wash tub.
Sep 04, 2015 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
How do I set my water level higher
The water level is automatically controlled by the machine and cannot be adjusted manually.
Oct 19, 2014 | LG WT4870CW Top Load Washer 4.5 Cu. Ft
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
LG WT4870CW 4.5 Cu. Ft. Top Load White Washer Logo
51 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
