Question about Pioneer VSX-D511 Receiver
Pioneer vsx d512
Hi I have a pioneer reciever vsx d512 i have recently purchased a computer from hp and would like to connect the coaxial out from the computer for sound digital into the pioneer reciver and have connected it to the coaxial cable input in the back of the vsx d512 system, but i have lost my manual and have no idea how to set up my reciever to play the sound. what do i have to do to make the sound play from this channel or port. can someone please help me. i am using an hp media center pc.
  • 2 more comments
  • Jonathan King Aug 04, 2007
    Hi I tried to follow these steps and still have no luck. If anyone can help, the Pioneer VSX D51 has a input jack at the back for dvd/ld and on is optical the other is coaxial.
    I have my optical cable for my home entertainment system plugged in to the optical in and have tried to plug my HP desktop computer in through the coaxial input using a coaxual cable from the digital output of the hp that is for coaxial out. i still am unsure what settings to click on the reciever unit which channel to choose etc. all i want is the sound to work. does anyone know where i can get a manual or what channel to choose to listen to the coaxial input option on the reciever unit. i i knew i was on the right channel i could do the rest from there. which channel is the coaxial input on the unit. what do i press on the remote.
    Thanks guys you really do provide a good service.
  • nethdale Dec 09, 2007
    Hi, I've a set of Pioneer VSX-D512 AV receiver. Today, when I tried to play a DVD disc, the dialogue is bearly audile but the background is perfect. The player has served me well over the year until today. I noticed that "sp-A" appeared on the panel of the receiver. I remembered vividly this may have caused the problem of the dialogue getting soft! May I know how to turn off this 'sp-A' or make it disappear from the receiver? Thank you very much.
  • Anonymous Mar 16, 2014
    my pioneer vsx-d711 plays fine for 10 minutes and then a large hum occures. When I turn the reciever off it makes a loud pop.
  • Anonymous Mar 21, 2014
    please help
  • 58 Answers
Try to disconnect everthing and use only the coax, and find the right input until you hear the sound from your PC. Use your remote to help your problem, and the unit buttons.
Posted on Aug 04, 2007
  • 63 Answers
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Posted on Aug 03, 2007
  • bengsoon Neo Aug 04, 2007
    you are almost there,the only problem is you get the wrong output from the HP computer (digital output).you should get the audio output.the output that is green in color normally connected to specker unit.that cable can buy from any electrical hardware shop,one end of the cable is RCA type the other is like normal mp3 headphone type.
SOURCE:
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
Display message "DSP NG"
Hi pay attention to do all interconnections right
You can get help dowlowding a low cost service manual at link below:
http://www.smpcshop.com/VSX-D414-VSX-D512-p-5216.html
Have a nice day and Good luck
Feb 21, 2008 | Pioneer VSX-D511 Receiver
VSX-D512
The best way to do this (if you haven't done this already) is to enable the Dynamic Range Control. This neat little setting makes the difference between loud and soft to be not so much, making soft sounds (like talking in your case) louder and something like explosions not so loud. This is also called Midnight Mode on some receivers. To enable this setting, grab your remote and turn the receiver on. Press the "Receiver" button, then hit the left arrow on the remote until you see something along the lines of "Dynamic range control" pop up on the LCD (should be the 8th setting). You probably want to set this to "Max", but you can also select "Mid" if you find that Max does too much.
If this still does not work, you can bump up the relative volume of the center channel a bit (or a lot of bit). Hit the "Standard" button on your remote, then "Test Tone" until "C" or "Center" comes up on the LCD. Then hit the "Level +" button a few times, making the center channel a little louder. Listen to it a while and adjust it to your liking.
The combination of these two settings should get you where you want to be. By the way, do a search on your favorite search engine for something like "manual Pioneer VSX-D512" and you should be able to download a manual from somewhere (it looks like Pioneer no longer hosts the manual on their site). Hope this helps!
Dec 19, 2007 | Pioneer VSX-D511 Receiver
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Nov 16, 2007 | Pioneer VSX-D510 Receiver
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
Pioneer VSX-D511 Receiver Logo
1,096 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
