Question about Misc - MFG 128401-010116 Lomita Pga370 Motherboard Rev D P/N: 128401-010116
Where do I install power cable on 128401 LOMITA 010116 motherboard
Please suggest me a computer repair company near Avalon City who are able to troubleshoot my problem?
Here are the 3 closest listings for computer repair near Avalon, CA :
Catalina Computers
125 Metropole Avenue # 104, Avalon, CA
Fusion Computer
24705 Narbonne Ave # 106, Lomita, CA PC Nerds Onsite
771 West 9th Street, CA
Dec 23, 2013 | Computers & Internet
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
M3A770DE 4 pin
Due to the 'large expanse' of information you posted I can barely contain myself.
1) 4-pin ATX +12 Volt power cable, that plugs into the motherboard,
Note that this power cable has TWO Yellow 12 Volt wires.
Back in the day there was no additional power cable needed, for the motherboard.
When the Intel Pentium 4 came out, the 4-pin ATX +12 Volt power cable came out also.
Power for the Processor.
More, and more powerful hardware components for the motherboard, (Processor and graphics card), required more power to the motherboard.
The 6-pin PCI Express power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
This power cable was used to connect directly to a graphics card, and provide power to it.
Note that this power cable has THREE Yellow 12 Volt wires.
It can carry up to 75 Watts of power.
Still wasn't enough power TO the motherboard, and TO the graphics card, with the new hardware component technology being brought out.
The 8-pin EPS +12 Volt power cable was brought out,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
Note that this power cable has FOUR Yellow 12 Volt wires.
Is capable of providing up to 150 Watts.
A PCI Express x16 slot is capable of providing 75 Watts.
Note the shape of the sockets in the connector.
Now compare to an 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
DO NOT confuse the 8-pin EPS +12 Volt power cable, with the 8-pin PCI Express power cable.
They are NOT the same.
The 8-pin EPS +12 Volt power cable's connector on the motherboard, is at the top left corner of the Processor socket, and close to the outside edge of the motherboard.
(With motherboard installed in computer case)
You can use the motherboard with just a 4-pin ATX +12 Volt power cable.
Look at the LOCK on the side of the 8-pin EPS +12 Volt power cable's connector.
With that Lock AWAY from you, or on the opposite side of the connector, a 4-pin ATX +12 Volt power cable plugs in on the RIGHT side.
If you have a powerful graphics card installed in your
PCI Express x16 -> slot/S, you had definitely better use a Power Supply that has an 8-pin EPS +12 Volt power cable.
This is a 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Misnomered as a 'Molex' power cable.
{ Molex was the first to design and produce this style of power cable CONNECTOR. The name stuck. Kind of like calling an open-end wrench a Crescent wrench }
IF you use an adapter power cable; Use TWO 4-pin standard Peripheral power cables!!
You need those Yellow 12 Volt wires.
What will happen if you do not use two?
1) The PCI Express x16 slot/s will burn.
2) The gold plated contact pins on the PCI Express graphics card, or cards, will burn.
3) If the graphics card, or graphics cards, require a power cable connected to them;
A) The connections on the graphics card for the power cable will burn.
B) The power cable connector will burn.
Other than that the only other 4-pin references on the motherboard, that I can see, is the optical drive's 4-pin audio cable connector on the motherboard, (CD1), and the CPU (Processor) Fan 4-pin connector on the motherboard.
For additional questions, or if the above is not what you seek, post in a Comment.
Regards,
joecoolvette
Oct 08, 2012 | Asrock M3A770DE ATX AM3 AMD770 DDR3...
Have A Lomita Trigem with two 256MB Ram, is it possible to increase obove 512,tried 512 sticks would not work.
Trigem Lomita Motherboard Memory Trigem Lomita Motherboard Memory Maximum Memory 512MB Memory Slots 2 (2 banks of 1) non-removable base memory 0MBhope it helps
Apr 16, 2012 | Computers & Internet
I have installed my abit nf8-v2 motherboard into my computer but i can not get my computer to power on. LED 2 is turning on but not LED1
Please verify that you have completed the following:
  1. Connected the cables from power supply to the motherboard
  2. Connected the processor fan power connector
  3. Installed the memory correctly
  4. Connected IDE/Sata cables correctly
  5. Processor installed correctly with fan sitting correctly
Feb 08, 2011 | Abit NF8-V2 ATX Motherboard with NVIDIA...
How to install amd 64 mother board cd
install the flat cables coming from the hard disk drive, optical units and floppy disk drive. If you didn't install these devices to the case yet now it is a good time to do so. The cable from the hard disk drive must be installed on the IDE1 (primary) port and the cable from the optical unit must be installed on the IDE2 (secondary) port. The floppy cable should be installed on the floppy port. To install the cable, just pay attention on the red wire, it should be installed facing the "pin 1" marking on the motherboard. This marking is usually a number "1" or "2" painted on one of the sides of the connector (the opposite side should be marked "40" or "39", or "33" or "34" in the case of the floppy port).
imageview.php?image=631
Figure 19: Cables from the hard disk drive, optical unit and floppy disk drive correctly installed.
The next step is connecting the power supply. The power supply has one 20-pin connector and your motherboard can have an extra 4-pin connector called ATX12V, which should also be installed (not all motherboards have this extra connector). You may need to lift the motherboard in a 45º angle with the table you are using to assemble your PC, since usually the wires from the power supply aren't long enough to reach the motherboard while it is on the table outside the case.
imageview.php?image=632
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Hi i buy all pc parts but i can't fit it how can i fit it?
Step 1: Installing the motherboardp1010185.jpgMake sure you have all the components in place and a nice, clean and big enough place to work with.
Put your antic-static wrist ******** to prevent your components from getting affected. Make sure your hands are clean before starting. First we will be installing the motherboard which is a piece of cake to install.
  • Open the side doors of the cabinet
  • Lay the cabinet on its side
  • Put the motherboard in place
  • Drive in all the required screws
Tip: Most motherboards come with an antistatic bag. It is advisable to put the motherboard on it for some time and then remove it from the antistatic bag before placing it in the cabinet.
Step 2: Installing the CPUCPU is the heart of a computer so make sure you handle it properly and do not drop it or mishandle it. Also try not to touch the pins frequently so that they do not get dirty. Get hold of your motherboard and CPU manual. You need to place the CPU on the dotted white patch of the motherboard in a particular fashion for it to fit properly. There is a golden mark on the CPU to help you assist. Consult both your motherboard and CPU manual to see which position it fits exactly or you could also use try all the 4 positions.
  • Lift the CPU lever on the motherboard
  • Place the CPU properly on the motherboard
  • Pull down the lever to secure the CPU in place
Warning: Do not try to push the CPU into the motherboard!
Got the thermal compound? Now is the time to use it. Take small amount of it and carefully apply it on the top surface of the processor. Be careful not to put it on the neighboring parts of the motherboard. If you do so clean it immediately using the cloth.
Tip: Thermal compounds should be changed once every six months for optimal performance.
Step 3: Installing the heat sink0181.jpgAfter installing the processor we proceed to installing the heat sink. There are different kinds of heat sinks that are bundled with the processor and each has a different way of installation. Look into your CPU manual for instructions on how to install it properly.
  • Place the heat sink on the processor
  • Put the jacks in place
  • Secure the heat sink with the lever
After this you will need to connect the cable of the heat sink on the motherboard. Again look into the motherboard manual on where to connect it and then connect it to the right port to get your heat sink in operational mode.
Step 4: Installing the RAMinstallingram.gifInstalling the RAM is also an easy job. The newer RAMs ie. DDR RAMs are easy to install as you don't have to worry about placing which side where into the slot. The older ones, SDRAMs are plagued by this problem.
If you want to use dual channel configuration then consult your manual on which slots to use to achieve that result.
  • Push down the RAM into the slot
  • Make sure the both the clips hold the RAM properly
Step 5: Installing the power supplypsu1.jpgWe will now install the power supply as the components we install after this will require power cables to be connected to them. There is not much to be done to install a PSU.
  • Place the PSU into the cabinet
  • Put the screws in place tightly
Tip: Some PSU have extra accessories that come bundled with it. Consult your PSU manual to see how to install them.
Step 6: Installing the video card 110665-2107p146-5b.jpgFirst you will need to find out whether your video card is AGP or PCI-E. AGP graphics cards have become redundant and are being phased out of the market quickly. So if you bought a spanking new card it will certainly be a PCI-E.
  • Remove the back plate on the cabinet corresponding to the graphics card
  • Push the card into the slot
  • Secure the card with a screw
  • Plug in the power connection from PSU (if required)
High-end graphics cards need dedicated power supply and if your graphics card needs one then connect the appropriate wire from PSU into the graphics card.
Step 7: Installing the hard disk042b.jpgHard disk is another fragile component of the computer and needs to handled carefully.
  • Place the hard drive into the bay
  • Secure the drive with screws
  • Connect the power cable from PSU
  • Connect the data cable from motherboard into the drive
If your hard drive is a SATA one then connect one end of SATA cable into the motherboard and other into the SATA port on the hard disk. If your hard disk is PATA type then use the IDE cable instead of the SATA cable.ide-sata.jpgTip: If your PSU does not support SATA power supply then you will need to get an converter which will convert your standard IDE power connector to a SATA power connector.
Step 8: Installing optical driveThe installation an optical drive is exactly similar to an hard drive.027.jpg
  • Place the optical drive into the bay
  • Drive in the screws
  • Connect the power cable and data cable
Tip: When installing multiple optical drives take care of jumper settings. Make sure you make one as primary and other slave by using the jumper. This is not applicable if the drives are SATA drives.
Step 9: Connecting various cablesFirst we will finish setting up internal components and then get on to the external ones. You will need to consult your motherboard manual for finding the appropriate port for connecting various cables at the right places on the motherboard.
  • Connect the large ATX power connector to the power supply port on your motherboard041a.jpg
  • Next get hold of the smaller square power connector which supplies power to the processor and connect it to the appropriate port by taking help from your motherboard manual
  • Connect the cabinet cables for power,reset button in the appropriate port of the motherboard
  • Connect the front USB/audio panel cable in the motherboard
  • Plug the cable of cabinet fans
You are done with installing the internal components of the PC. Close the side doors of the cabinet and get it upright and place it on your computer table. Get the rest of the PC components like monitor, keyboard, mouse, speakers etc. which we will connect now.
  • If mouse/keyboard are PS/2 then connect them to PS/2 ports or else use the USB port
  • Connect the speaker cable in the audio port
  • Plug in the power cable from PSU into the UPS
  • Also plug in the power cable of the monitor
You are now done with setting up your PC. Power on and see your rig boot to glory.
Step 10: Installing the OS and driversWe are done with the hardware part. Now get your favorite OS disks ready and the CD that came with your motherboard.
  • Set the first boot device to CD/DVD drive in BIOS
  • Pop in the OS disk
  • Reboot the PC
  • Install the OS
  • Install drivers from motherboard CD (applicable only to Windows OS)
Voila! You have your PC up and running. Enjoy your journey with your self assembled rig!
Jargon Buster
  • CPU - Central Processing Unit
  • RAM - Random Memory Access
  • DDR -Double Data Rate
  • SDRAM - Synchronous Dynamic Random Access Memory
  • PSU -Power Supply Unit
  • AGP - Accelerated Graphics Port
  • PCI-E - Peripheral Component Interconnect- Express
  • SATA - Serial Advanced Technology Attachment
  • PATA -Parallel Advanced Technology Attachment
  • IDE - Integrated Drive Electronics
  • ATX - Advanced Technology Extended
  • USB - Universal System Bus
  • VGA - Video Graphics Array
  • PS/2 - Personal System/2
  • OS - Operating System
Nov 13, 2010 | Computers & Internet
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Want to disable onboard ethernet port need to know settings for jumpers on motherboard
TriGem 011027 (Lomita)
As far as I know the only jumper settings for this motherboard are very limited. The jumper settings stated on the link above are for clearing CMOS settings and Clearing Bios password.
I would suggest booting into the Bois settings to see if you can disable the on board Ethernet controller there, it should be in I/O devices settings.
Hope this helps, take care
May 05, 2009 | Intel Motherboard
Misc - MFG 128401-010116 Lomita Pga370 Motherboard Rev D P/N: 128401-010116 Logo
41 people viewed this question
Top Misc - MFG Computers & Internet Experts
David Payne
David Payne
Are you a Misc - MFG Computer and Internet Expert? Answer questions, earn points and help others
