Question about Master Appliance Mini Ultra Butane Soldering Iron
It will not spark or lit - Master Appliance Mini Ultra Butane Soldering Iron
Pilot ignition continuous spark
Sounds like thermostat or no fuel. Gas lines on? Correct orifice for the type of gas youre using?
May 15, 2016 | Pitco Frialator SG14 Deep Fryer
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
Burner will not ignite but electroic spark s are working, sparks will not stop after burner is manualy lit
I have had this same issue with continuous sparking after a burner was lit.
Problem 1. Wet or dirty ignitors/burners. Solution: clean and/or dry (I assume this resolves electrical issues). This has usually solved the problem
Problem 2. Stuck or dirty control switch. Solution: remove knobs and spray electrical-cleaner into switches. AMAZING... no more clicking plus burners now burn hotter when set to HI. I assume this frees-up the movement of the switch to prevent it thinking you are pushing it ON... and thus asking for spark... plus greater range of switch and/or higher flame settings available once lit. A no-cost miracle! ( I used "PureTronics" brand Electrical Contact Cleaner spray can, 1 sec, 2X).
Mike S
Sep 15, 2011 | Viking 37 in. VGSU161 Gas Cooktop
The ignition - clicking - continues after burner has lit - all 5 burners have this issued
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 31, 2011 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
How do you change spark plugs in a 2004 hyundia sonata
It depends on which engine is in the vehicle. The 2004 Sonata came with two possible powertrains -- the 2.4 Lit L4, and the 2.7 Lit V6.
On the 4 cylinder engine, there are two coil packs and two ignition wires, Below each coil pack is a spark plug (#2 and #4 cylinders). The wire from # 2 coil pack goes to #3 spark plug, and the wire from #4 coil pack goes to #1 spark plug.
Photo:
Now the 2.7 Lit V6 requires you remove the surge tank (intake manifold) in order to access the spark plugs & wires on Bank 1 (Right Hand side of the engine).
Photo:
Jun 10, 2011 | Hyundai Sonata Cars & Trucks
Ignitor is constant even when lit.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jun 24, 2010 | Jenn-Air JGA8100A Gas Cooktop
I can not lite the pilot
Turn the control knob to "pilot", while holding the knob down, press the piezoelectric spark button repeatedly until you see the pilot light through the observation glass. Once its lit, hold the button for approximately 30 secs. If it stays lit when you release the knob, turn to "on" Then operate normally. If the piezoelectric is not sparking, you can open the glass and light manually. Good luck and please rate my answer if it was helpful.
Dec 29, 2009 | Williams 1403622 Gas Compact Heater
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Master Appliance  Mini Ultra Butane Soldering Iron Logo
24 people viewed this question
Top Master Appliance Welding Tools Experts
Bill Boyd
Are you a Master Appliance Welding Tool Expert? Answer questions, earn points and help others
