Question about Proview PL 566s 15" Flat Panel LCD Monitor
900Proview 19in.Flat panel LCD Monitor
Will Not Power up
  • 1 more comment
  • Robert Wedge Aug 11, 2007
    power supply bad can not find one
  • Anonymous Apr 08, 2008
    Lights on for 1/2 second. Wont power up. Less than 3 months old
  • billrwynne Nov 15, 2008
    Same result, BUT I do have a power Green Light and a Amber when no source is applied, it's approximately 29 months old and I leave my system running continually 24/7 unless the power gets cut off
    Brigadier General:
  • 6,966 Answers
Hi, If no indicator lights, no reaction when push the power on button, then chances are that you have a power supply problem. If your particular brand/model has a built-in power supply then it has to be opened up and diagnose. Normally most units would show a light indicator by simply plugging it into an outlet. That light changes color or another one lites up when the power on button is pressed. Absence of the first light indicator means that the system is not getting any power at all. You would be better off seeking the services of a qualified professional. But then again, it just might be the power cord which is of course relatively easy to replace. Try using your computers cord first for the monitor if it fits and matches. Hopes this work out for you and give you an idea or two. Pls post again how things turn up. Good luck and kind regards.
Posted on Aug 03, 2007
SOURCE:
How do I navigate Menu for colors, brightness, etc.?
Howard
Hello
Some monitors you can configure, in options video, inside windows. and configure , contrast, or brighness too.
if you can go into menu in your particular monitor, then you can in advanve, change those settings. and save them.
good luck!
Nov 14, 2015 | Gateway FPD1975W 19in Flat Panel TFT-LCD...
Looking for circuit board for a 19in proview lcd monitor
Which pc board are you looking for? Most LCD monitor companies use third party PCB assemblies. Can you get the name and number as printed on the PCB?
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Star logic 19inch computer monitor power adapter STD-1205
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
Jul 27, 2008 | Star Logic 17" LCD Monitor
Dark screen
The problems it the inverter is burnt out... Need replace new inverter. contact me, I'll give you a good price. [email protected]
Dec 06, 2007 | Fuji FP-988D 19" Flat Panel LCD Monitor
Proview PL 566s 15" Flat Panel LCD Monitor Logo
150 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
