Question about Pyle AMFM CD DET MARINE RADIO R/C
How to hook up 2 speakers to a radio with 4 speaker hookup
How to hook up speakers
2 Suggested Answers
jpenn1192
  • 58 Answers
SOURCE: We have our power supplies. THe problem is hooking
first u need a set of RCA cables,u can pick them up at any car audio shop, plug them into the audio outputs on the back of the radio,run the other to the audio inputs on your amp,from there jus plug the speaker wire into the speaker output on amp then to your speakers.
Posted on Jul 18, 2010
RCA & speaker hook up
I need code for : Blaupunkt GMBH 7 612 001 015, BNO 881. Made in Germany. Radio navigation AU Z1Z1B6079922
Thanks. my e-mail: max_zoki@hotmail.com
Best Regards.
Jul 15, 2013 | Car Audio & Video
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Can i hook up 4 8ohm speakers to my marantz 2252b
You can but you will have to put two speakers on the main L/R and two speakers on the remote L/R. DO NOT HOOK UP MORE THAN ONE SPEAKER TO A CHANNEL. Doing so can result in the amp running hot and damage will occur.
Oct 25, 2012 | Marantz Vintage 2252 B Stereo Receiver...
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
I just needed some help with wiring my p8002 rockford amp to 2 fosgate 10 inch subs i just bought. there 4 ohms a piece and dual voice coil. i dont know much about car stereos but people keep telling me...
Well i tried looking up that amp, but Fosgate sight is down. So assuming that the best power out of your amp is 2ohms off the bridged hookup, and the subs are 4 ohms per coil, the best way is to only use one side of each speaker and hook it straight the the bridge. Only using one hook up wont hurt anything, its just for giving you wiring options. And when adding up ohms of speakers, it goes like this. If you had two 4 ohm subs, that'll give you a 2 ohm load. If you hooked up all your hookups, it would be like having four 4 ohm subs, and would give you a 1 ohm load.
Jan 19, 2011 | Car Audio & Video
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
I just bot Pioneer speaker CH26861...4 wires to 2 leads...
I would tie both + from the speakers to the radio, and both - as well. This will give an equal amount of power to both speakers and reduce the chance of blowing a speaker. As for +&- on the speakers, It is usually marked on the black piece right by the terminals. As little power as you are putting to the speakers, it doesn't really matter which way you hook them up, as long as they are both hooked up the same.
Jul 30, 2009 | Car Audio & Video
Jensen vm9411 has no sound from radio hookups put rca wires have sound
If the previous radio played all the speakers and the new one wont either:
1. You have not hooked the speakers up right.
2. All your speakers are blown.
3. There is a factory amp, you just don't know about it.
4. The radio has blown final outputs.
5. One or more speakers or speaker wires is seeing a ground (shorted out)
First check the radio, hook up a know good test speaker directly to the speaker outputs on the radio. If it works, then take a 9volt battery and try to pop the inside speakers with it. When you touch the + & - speaker wires to the battery + &- you should hear a pop at the speaker. If you do you don't have an amp. If you don't you might have an amp or the wire going to the speaker is dead or shorted out. It is unlikely that all four speakers would be bad or have bad wires. If none of them will pop you need to turn on the factory amp. Then they will play. If only one speaker wont pop then that is the bad speaker. If they all pop then you have a bad speaker or wire.
Dec 18, 2008 | Car Audio & Video
Pyle AMFM CD DET MARINE RADIO R/C Logo
24 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
