Question about Gateway /Creative SoundBlaster Sound Card
Crackling in my speakers occasionally when playing audio, what should i do?
Don't listen to this person. they obviously don't know what they're talking about if they don't observe ALL posibilities before stating just ONE solution.
A number of things could be causing this issue. First, try unplugging all connecting wires from your PC to your speakers, making sure they are completely untangled, and maybe a small sharp blow on the jack plus to make sure they're clear of dust etc, then plug them back in. If this doesn't help, it's time to go under the hood. Open your PC up (if you have sufficiant knowledge. If not it's probably best to leave it to a professional or someone who knows what they're doing), remove your sound card, clean the contacts with something soft (like a cloth or eraser) and re-insert your sound card. Also, make sure all your drivers are fully up to date, and scan your system for any malicious software/malware. If NONE of this works THEN consider having your speakers looked at/replaced.
Posted on Dec 15, 2009
  • 76 Answers
Speakers are busted you need a replace ment
Posted on Mar 12, 2009
Crackling static in sound
reduce the volume of the microphone
Mar 25, 2014 | HP ProBook 5310m (FM997UT) PC Notebook
Crackling and scratching
Your speaker may be blown take out the speaker that is hooked up and attach another one a house speaker would even work, and i bet your speakers are blow if not check the wires and make sure you have them connected properly if not check the wires going to the harness and to the speaker and if not i think the radio is fried you can also take a long speaker wire take radio out the dash and run it to the speaker if it does still the radio is fried take it back before 90 days is up!
May 29, 2013 | Pioneer Car Audio & Video
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
Fuzzy crackling sound from front right speaker only -tried switching speakers and speaker wires with front left and the right still gets fuzzy and crackles
Look to the source. Try switching or reseating any cables between it and the speakers.
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you
rarely use, like a Tape Monitor. It's wise to occasionally (with power OFF) operate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Jan 29, 2011 | Audio Players & Recorders
Hi, I get very intermittent hissing/crackling from the left channel of my NAD C370. I've replaced the speaker wire and the wire that I'm using for bridges on my AE Evo 3 speakers which seems to have...
Could be caused by a burnt resistor in the channel of the main power amp. You should be able to see it. It might have been caused by the faulty speaker wires.
Oct 07, 2017 | Audio Players & Recorders
Crackling sound, with occasional loss of sound
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you get the crackling sound there also, if you do, then the problem is in the sound processor circuit. Please post back what you find. If not, then the power section is bad. If you can live with sound from the Powered speakers, you may want to keep on using it that way, just muted the speakers in the sound setup menu, otherwise the repair bill can be in the $200~300 range.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 06, 2010 | Protron PLTV-4250 42 in. LCD Television
Sony KV-20FS120
Do you get sound when you play a dvd thru audio/video inputs?
If this unit has audio output at the back run audio to amp and see if you have audio thru your stereo
Jul 23, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Apr 30, 2008 | Bose SoundDock Digital Music System for...
JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Apr 23, 2007 | JVC RX-558V
Gateway /Creative SoundBlaster Sound Card Logo
279 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
