Question about Air Tools & Compressors
Devilbiss compressor won't unload - Air Tools & Compressors
2 Suggested Answers
  • 4 Answers
SOURCE: Looking for owner's manual for DeVilbiss compressor, 1950's era, SN 10421
Owners manuals can be found online here. The link is for air compressors is currently not working for me however if you contact the company then they may be able to email you. Here is their webpage... http://www.devap.com/manuals_splash.asp
Posted on Nov 13, 2014
Devilbiss 4hp 30 gallon air compressor wiring I
By safety valve you mean the tank overpressure release valve? Find the opening size in the tank first. Determine your compressors top psi it reaches when fully allowed to fill to max psi. Order valve that is rated ten psi more with that size fitting. Any brand will work, you just need that info and you can easily get one. It's hard to find exact parts for compressors but they are all basically the same setup
Oct 22, 2017 | Air Tools & Compressors
Won't cycle on
Check the switch, they combine the power, pressure and unloader all in one unit.
Jun 06, 2013 | Air Tools & Compressors
Devilbiss air compressor Running hot and low pressure
Chris:
Sounds to me like you have an air leak somewhere. When the compressor motor runs for too long a time, it's 'gonna get hot! Disconnect the fittings one at a time and use Teflon tape at each air connection. Check for leaks using a soap and water solution at each fitting.
Jun 02, 2013 | DeVilbiss Air Tools & Compressors
Compressor won't turn on or off with the switch no idea why help please
The key is the last part of the video, the part that wont move is unloader valve. The pressure switch under the lever is sticking and not allowing the switch to close.
Mar 11, 2013 | Air Tools & Compressors
Dec 07, 2012 | Televison & Video
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Sep 09, 2012 | Dewalt D55153 1.1 HP Continuous 4 Gallon...
Compressor won't start
Try dumping the compressor so it does not start under a load. sometimes the unloaders get stuck. you can do this by pulling the pin on the pressure relief or opening the bleader on the bottom of the compressor. Be careful when doing this because particals and water can be exausted when you do this.Capacitor can be tested but it has to be unloaded or you will get a bad shock. Some autopart stores check them if they offer the service.
Feb 19, 2012 | Kenmore Side by Side Refrigerator
Air Tools & Compressors Logo
19 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
