Question about Canon Office Equipment & Supplies
Canon NP 6030 hasil fotocopy gelap - Canon Office Equipment & Supplies
valentinobar
  • 3 Answers
SOURCE: NP 6050 hasil foto copy
hasil copyan canon np 6050 terkadang tidak ada hasil kadang ada tapi belang dan buram
Posted on Apr 09, 2012
  • 62 Answers
SOURCE: Canon NP 6030 dark copies
Have you cleaned the slit-glass located behind the drum? Its a thin piece of glass that is about the length of a drum assembly. Check that the drum voltages on the drum label have been correctly installed. Perform a AVPC in service mode to set the primary charge value.
Posted on Oct 24, 2007
SOURCE: Canon NP 6030 Error code E010
chiudere sportello superiore destro
Posted on Oct 16, 2009
  • 149 Answers
SOURCE: i want to download technical support manual for
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Posted on Jun 18, 2010
Cogz
  • 1326 Answers
SOURCE: e065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Posted on Mar 11, 2011
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E210 remettre copieur sous tension, bagaimana ?
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E000 remettre copieur sous tension, bagaimana ?
Feb 07, 2013 | Canon NP 6650II Copier
Cara mengatasi hasil fotocopy buram
cara mengatasi hasil fotokopian yang buram/banyak bercak hitam
Sep 23, 2012 | Canon NP 6035 Copier
Bagaimana cara memperbaiki mesin photo kopi canon 6050. muncul tulisan e210
saya punya NP 6050, tidak ada hasil copyan sama sekali, apa yang perlu di cek
Mar 30, 2012 | Canon NP 6050 Copier
Gimana cara hilangkan garis hitam pada hasil gambar foto copy
Ikut pengalaman saya,sekiranya setiap salinan ada garis hitam,bapak hendaklah menukar Cleaning Blade dan hendaklah dilakukan oleh yang mahir sahaja
Sep 17, 2011 | Canon NP 6050 Copier
Hasil copyan tidak jelas canon np 6050
bapak hendaklah mencuci bahagian Optical Unit (Reader) dulu dan barulah dilakukan Adjustment.Hendaklah dilakukan oleh yang arif tentang mesin ini
Sep 09, 2011 | Canon NP 6050 Copier
Gambar tiba-tiba hilang saat tv on?
hallo bagus,
Gambar hilang seperti apa ya?
1. kalau hilang suara ada, coba cek backlight nya dengan cara mengetuk panel .
jika di panel keluar cahaya (ditempat diketuk), itu tandanya backlight masih bagus, masalah berasal dari T-con atau pcb main.
jika diketuk tdk terlihat apapun, backlight rusak. Bisa rusak neon atau pcb inverter nya. klo neon rusak harus ganti 1 panel, tapi klo inverter rusak, bisa beli di service center.
2. kalau gelap dan tidak ada suara ; kemungkinan kerusakan dari power supply.
jika punya pengalaman di elektronika, coba ukur fuse dan kabel ac cord nya.
Semoga berhasil bro.
Mar 23, 2011 | Samsung LN32A330 32 in. LCD TV
Enter ID Number with the Number keys canon 6030
I have a Canon photocopier NP 6030. Problems on my machine, the display panel is written ENTER ID Number ......., How does the solution sir? Listen Read phonetically
Mar 04, 2011 | Canon NP 6035 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
107 people viewed this question
old marine
old marine
