Question about Hitachi 51F59 51" HDTV Projection Television
Cant find HDMI input on tv, trying to hook up ps3
I plug in the HDMI cord in tv and ps3, then i change inputs but none of them is the HDMI input. So i dont see the ps3 screen.
  • sara turnock Feb 03, 2013
    We are having the same probem and done worked!! Thank you so much! We can now watch a film in bed!! x
  • 3 Answers
Hdmi output is" INPUT 1" on the menu ALSO hold down on the ps3 power button for 6 seconds and it should come on. the ps 3 has a thing were you have to set it to send out in hdmi or comp.
Posted on Mar 19, 2009
  • FJR7581 Feb 12, 2011
    OMG Thank You ! You are our hero !
    New Friend:
Im having the same problem, help please
Posted on Mar 22, 2013
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
I have lost all my HDMI inputs for my Hitachi L42X01AU, i had my PS3 hooked up and it worked but now when i hook it up none of the HDMI inputs work
try unplugged all units involved---HDMI does not like being hooked or unhooked with units powered and or on.
Wait a while and make the connections and then power set, box, whatever is inline back---the units will try to reboot and that may cure the issue- it is worth trying
Jun 17, 2012 | Hitachi Televison & Video
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I cant figure out how to hook up my hdmi how do i do that
Plug the hdmi into the TV, then into your dvd, cable box, PS3, etc. Then change the "video input" on the television to correspond with the hdmi input. This is typically done, just using the remote, but it may have several labels on the button. It could read as something like, "Input, Video, source, etc.",
Sep 09, 2009 | Sony Playstation 3 (PS3) Console
None of the connections for my ps3 will work with my 32lb30q proscan 32 inch lcd flatscreen?
The product description says that your TV has 2 HDMI inputs. All you need is an HDMI cable to hook it up.
It also says that it has the A/V inputs (red/white/yellow). Which you just plug in the cord that came with the PS3, each plug with the corresponding color. Good luck and thank you!
Jan 13, 2009 | Video Game Consoles & Games
Ps3 to tv
if your using hdmi, all you have to do is plug it in, and change your tv input to the hdmi input
Jan 07, 2009 | Televison & Video
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Hitachi 51F59 51" HDTV Projection Television Logo
1,646 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
