Question about Drills
Looking for parts rockwood drill press
Bulb socket
2 Suggested Answers
SRF518
  • 232 Answers
SOURCE: Hi I'm looking for a part for a drill press
check out this url:
www.jalopyjournal.com/forum/showthread.php?t=237685
Posted on Oct 20, 2009
Why does 2003 Acura TL low beam right headlight keeps burning out?
Your ignitor and control unit for that headlight is going bad. Replace those with a new bulb and you will be good to go. Its number 4 in the picture.b41df67d-b738-4d7f-9e4d-7f0a23de09ae.png
Aug 13, 2014 | 2003 Acura 3.2TL
I pushed the switch on my work light , it was on for a second then off, as if the light bulb burned out, the light bulb doesnt look bad, what could it be?
Take the bulb out and if you have a multi tester give it a continuity test by hold the red test probe on the base and the black probe on side where the threads are.if you get a beep then the bulb is good.Next unplug the machine and look in the socket.If there is a metal tang in the bottom of the socket try bending it up with a paper clip with a L bent on the bottom so that it will make contact once again.I hope this will solve your problem.One other thought you can try es a small clamp on light.Thank for choosing FixYa.com and good luck.
May 16, 2011 | Makita 18 V 1/2" Driver Drill Kit With...
I want to put a taping head on my drill press. What is the spindle size of a craftsman 12" drill press?
without the model number I am going to guess that as a general rule most smaller drill presses are a #2 morse taper socket and a #2 jacobs taper arbor (where the chuck presses on) you should have been supplied a knockout pin to remove the chuck assembly from the internal socket.
Apr 15, 2011 | Craftsman 12" Drill Press (21914)
Tail lite has water in it about one fourth full how do I get it out without taking it apart
Get a tiny drill bit - (1/16inch ) . Look over the light assembly and drill into the lowest point, making sure you drill only into the lens and not the housing. **** the bit around a little to remove plastic burrs - this should get the water out. You may want to check with your local wrecking yards for a replacement light assembly as yours has a crack, allowing the water in.The water will cause corrosion in the bulb socket, eventually forcing you to replace several bulbs before you'll have to replace the socket.
Nov 17, 2010 | 1996 Oldsmobile Ninety Eight
The spindle with the chuck attached keeps falling out of my drill press. I can push the spindle (arbor shaft) up into the machine, but it later falls down. How do I fix this?
get something like brake clean and spray both parts the shaft and internal socket and then wipe with a paper towel. Next put the shaft into the socket and "tap" into place with a block of wood on the drill chuck with the jaws retracted. You might have to "tap" a little hard if you know what I mean but this will seat the tapers and you should not have a problem for a while.
Nov 16, 2009 | Drills
Passanger side turn signals don't work
First: press the brake and be sure that both sides light up. If one side does not, turn your attention to it. Remove the taillamp assembly from the suspect side and disconnect it. Unscrew the socket / circuit board and dismount it from the reflector. Take out the bulbs and examine the sockets, looking for melted / toasted / warped sockets. If they are bad, don't even bother trying new bulbs or attempting a repair; go to the parts store and get a new socket / circuit board assembly. Last I looked they cost about $25 apiece.
Nov 16, 2009 | 1988 Chevrolet K2500
check out this url:
Oct 20, 2009 | Drills
The shaft on my Delta floor mdoel press drill keeps sliding out
This sounds like a morse taper adaptor. if so look at the taper for any unusual wear. if none what I would do is get something like brake clean or similar product to remove all oil and grease. clean the shaft and the internal socket. wipe off with cleam paper towel after cleaning. retract the chuck jaws to prevent damage to the chuck and align the tang on adaptor with the internal socket. Take a piece of wood and hammer and hit the chuck seating the taper. You can also try using the table with a block of wood and the feed handle to seat it. If it continues to fall you have worn parts that need replaced. Good luck
Jan 06, 2009 | Delta 15IN Stroke Production Drill Press /...
Replace the headlight bulb
Remove the plastic access panel by pressing down on the tab at the top of the penel and pulling the top of the panel towards the engine and off. Needle nose pliers may help with the next steps to remove the spring clips. There are 2 bulbs, the top large bulb is the low beam. To remove it, first remove the socket attached to it, then press the top of the metal spring clip towards the front of the car and towards the passenger side (look closely at the clip to see the latch holding it. The clip then swings back towards the engine. Remove the old bulb, install the new bulb, replace the spring clip, re-connect the socket. (Don't touch the bulb, if you do clean it off with a lint free cloth and alcohol). To replace the lower bulb (parking light), remove the socket, then release the lower end of the spring clip, look closely and you'll see the latch holding it. You have to press it towards the front of the car and swing it towards the passenger side. It will swing up and release the bulb. Replace with new bulb, replace spring clip, connect socket. Don't forget to replace the plastic cover panel by inserting the bottom tabs into the sockets and snapping it closed at the top by pressing it towards the front of the car.
May 15, 2008 | 1998 Mercedes-Benz C-Class
Drills Logo
90 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
