Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Dream maker spa big easy shuts down . shows codes HH,OH,dr tech changed sensors checked filter,and refilled tub, 7hrs later is doing same thing. Tub is 4wks old
4 to 5 person tub
    Top Expert:
  • Dream Maker ... Master
  • 8,686 Answers
Recirculation pump bad
Posted on Sep 20, 2017
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Easy spa round - dream maker - overheat sensor is
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
Posted on Jun 18, 2010
adamh294
  • 310 Answers
SOURCE: motor will not come on.
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Posted on Apr 14, 2011
Testimonial: "very helpful. @We did not have the sensor connected properly in the panel board. Now it seems to be working fine. Thanks to you."
How can I choose the right hot tub?
There are a few things to think about when buying a hot tub. Your best option is to follow these four steps:
1. First, decide what you want from your hot tub. Do you want to use it for health purposes, such as hydrotherapy and massage? If so, you'll need to select a model that is equipped for that.
2. Next, decide how much you're willing to spend. Your budget will determine whether you should be looking for an entry-level, mid-range, or high-end hot tub
3. Then, decide how much space you have and the size of hot tub you want to fit in it. Do you have space/need for an 8-person hot tub? Or will a 3-person tub suffice?
4. Finally, decide what design you'd like and pick a brand such as sheds kent and other hot tub retailers that has what you're looking for. Would you like a Jacuzzi? Or perhaps you're interested in Beachcomber hot tubs? Find a product that's right for you.
May 04, 2018 | Pool & Spa
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
Hi i am paul. my bathroom is about 4 feet in width and 6 feet in length. Is there any tub fit in my bathroom.
if u buy any small tub it can other wise it cant :( sorry i guess you can think that ! :)
4rm : x_crystala_x
Jul 02, 2010 | Whirlpool 2 Person Corner Air Tub By...
Hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Is a 300 watt blower sufficient for a 72"x36" air tub?
the blower should be matched to the number of holes and diameter of the hole. there is a pretty precise science to the whole Air Tub product. if the blower is too large it will burn up and if it is too small you won't get the true benefits that an Air Tub offers.
Jan 07, 2009 | Whirlpool 2 Person Corner Air Tub By...
Marble slipped between the tub and the opening of duet washer
Sounds like you must disassemble the washer. Not that hard to do. Be sure and unplug it first!
Dec 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
552 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
