Question about Home
Ariance tub by mansfield manual. Can't get the off switch to stop blinking
Where can I get an 18v mansfield dual drill battery charger
Try this web site .http://www.zis4u.com/mansfield-battery-drill-charger-power-station-200510-p-2526.html
Dec 03, 2014 | Mansfield Drills
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
Just bought my 4runner and noticed there's two blinking lights on my dash. It looks like it has something to do with the the switch that says h4-h2. My car didn't come with a manual! I've
go back to the dealer and get the user manual and the service and warranty book ( new car)
or is it an old car that is new to you
in which sweet talk a dealer salesman to show you what operates what
Dec 11, 2017 | 2007 Toyota 4Runner
Mansfield holiday zoom model 501 8mm projector owners manual
Looking for a manual for Mansfield Holiday zoom 8 mm projector
Feb 06, 2013 | Office Equipment & Supplies
Night Sentry light will not stop blinking so I cannot set for auto. And I don't know how to work it manually. Thanks.
What kind of night sentry light is it? Some you turn them off at the switch and wait 3 to 5 mins and turn back on. then set to auto?
Jan 25, 2013 | Home Security
My Whirlpool washer fills up but won't stop poring into the washer. Is this something that is repairable?
Your water level switch could be defective. This switch has a plastic 1/4 hose connected from your tub to the switch. (should be easy to find.) Make sure this hose is connected to your tub and switch and the line has no holes. It is easy to test the switch by disconnecting the line from the tub and while water is flowing into your washer, Blow into the line. The pressure will stop the water flow. If not, Bad level switch.
Level switch part# W10339333
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool WTW5100SQ
MANSFIELD TOILET KEEP LEAKING
I'm not exactly sure where the seals are that you are describing. I'm thinking that you might need to shut the water off, unbolt the toilet from the floor, and replace the big wax toilet gasket underneath.
That's the main seal for internal plumbing in the toilet, unless you're talking about the toilet leaking into itself and wasting water. In that case you might need to simply adjust the mechanism (float, flapper valve etc.) to get the right setup.
I'm not sure I completely understand your problem though.
I hope this has helped anyway.
Lyle
May 03, 2010 | Mansfield Plumbing Products MANSFIELD 3/8"...
Connecting a mansfield whirlpool tub pump don't know the model number pump is in the floor and tough to get to. there are 2 cords hanging out. 1 male end and 1 female end. When I plug in the male end, the...
Hello Joe, Typically when you have a whirlpool type tub, there is either a built-in air switch on the tub that will turn the tub motor, on and off, or the tub needs to have a wall switch to turn it on and off.
The switch has to be located so it is at least a minimum distance of 3-4 feet from the edge of either a tub or shower stall, and it must be connected to a GFCI protected circuit. Normally any whirlpool tub requires a separate dedicated 20 Amp 120 Volt AC circuit for proper operation and to meet code.
I believe that the female plug is for an optional, in-line heater that can be installed into the tub unit. You should be able to check the installation manual that came with the tub to verify the proper wiring required for your specific unit and model.
I would contact the manufacturer to get a copy of the installation guide and instructions for your model, so you are certain that it is properly installed and the wiring you are using meet the NEC (National Electric Code).
Here is a link to the Mansfield web site with some FAQ's and their phone contact information.
http://mansfieldplumbing.com/v3/support02-03.html
I hope you find this Very Helpful and best regards!
Dec 11, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jets in my new tub will not turn on.
You could have a GFCI receptacle tripped or in test mode. look close to tub or in and around tub area for this. This receptacle has a test and reset button on it.
Aug 30, 2009 | Mansfield Plumbing Products Mansfield...
Home Logo
131 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
