Question about RCA HD61LPW42 61" Rear Projection HDTV
We have a rca hd61lpw42, just replaced lamp. Now set come on but we have no picture or sound.It keeps showing unuseable siginal. We have checked the signal source and it is set right.We have cable.
4 Suggested Answers
rustym62
  • 201 Answers
SOURCE: RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Posted on Apr 26, 2009
SOURCE: RCA HD61LPW42. No picture/sound.
TV stays on 30 seconds and turns itself off every time i turn it on
Posted on Jun 30, 2010
ladywinn
  • 5138 Answers
SOURCE: Picture occasionally goes out, still
Souns like the Lamp is going out ,If you have never replaced Lamp then that is what your Problem is Mats has them for $99.00 1-800-628-1118
Posted on Nov 06, 2010
Replacing bulb in hd61lpw42 rca. Question: I have replaced the bulb before but this time the glass covering the mirror is broken. I suppose the additional heat of the bulb cracked it. My wife said the...
lbcofer,
Just make sure that you purchase the entire module, not just the lamp. Also make sure that any glass is removed from the set. I have a tip at
http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv
which explains the process and where to get the best quality lamps at the best price. Do not use after market lamps or cheap lamps as they will explode as yours did and do not last as long as OEM lamps. In some cases they will not even be compatable with the equipment. The old adage about you get what you pay for, is definitely true in this case.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Feb 27, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Picture occasionally goes out, still have sound when this occurs and then the picture will come back on after a while. When the picture is out the lamp is off. Hd61lpw42 RCA DLP TV
Nov 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
My rca hd61lpw42 is having trouble. there is the loud whirring noise, and the whites on the show i was watching distorted and then the screen turned off. is the issue with the color wheel or the lamp?
it sounds like the lamp or fan. do you feel airflow? Unplug the set and wait. When you plug it up is the whinning imedate. the color wheel generally is the first thing to come on. If it dosent reach speed it will shut down
Oct 31, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Turning on but no picture at all
I would check to see if the lamp is actually comming on before anything else. The color wheel won't cause a loss of picture. Here is a link to purchase a suitable replacement lamp for the TV. It is 300 dollars less than the RCA version. http://www.partstore.com/Part/Thomson/RCA/HD61LPW42/Lighting+Technologies+International/LTI/260962RL/New.aspx
May 09, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Intermittent picture
Most likely your lamp needs to be replaced as that will cause the intr. picture issue. The color wheel will also have to be replaced. The color wheel is only available with the light engine which is part# 263223 and the lamp part #260962
Mar 05, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
27 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
