Question about Sub-Zero 632 / S
Temp Problem The temp of the unit seems to be to warm, what should the inside temp be?
  • Ingmard May 18, 2009
    same unit, fridge set at 34 is actually 43 degrees.
    freezer set 0 at -4. Not happy with this unit after 4 years with a couple service calls
  • 400 Answers
Sub-Zero, or freezers should generally be able to maintain -15 to -20c.
Posted on Mar 12, 2009
Effect of a bad thermostat
Engine running cold.mean open.engine overheating ,stack closed.
Jun 20, 2016 | Cars & Trucks
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
1997 Villager gas smell when outside temperatures are hot and vehicle has been driven.
A common problem with Nissan products, which this van is a Nissan Quest with Mercury trim.
There are several small rubber fuel hoses around the intake. When the air temp is cold these hoses can leak and then stop leaking when the air temp warms up.
When the air temp is cold, look around the intake with the engine running and you should see one of the hoses wet with fuel.
Just tighten the clamp.
Dec 12, 2012 | 1997 Mercury Villager
What should the temp gauge in my 2005 911 C2S read in "normal" operation? The engine seems to start and run beautifully, but I have noticed that the temp gauge inside the car shows the engine warming up to...
they are designed not to fluctuate with engine temp and are kept stable once operating temp is reached. only if the temp exceeds a set mark will the needle rise to indicate overheating,
Aug 31, 2009 | 2009 Porsche 911
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
UNIT NOT BLOWING WARM AIR-OR REACHING DESIRED TEMP
I assume this is a heat pump. The outside unit may be icing up. It should have a defrost cycle with electronic control that sometimes fails or sensor associated with the electronic determination of when to defrost may have failed or may not be sensing because its out of position. You can check for a defrost problem. If frost is blocking the outside unit air will not pass through it after the frost builds up and you may be able to see the white frost as well. If all this is true you need to get a service manual and use its procedures to find out why the unit is not defrosting.
Jan 12, 2009 | Weather King 12AJA4801AH Air Conditioner
Carrier heat pump: aux heat does not seem to work
The unit is probably to small for theare you are trying to heat.
When the Aux HT light came on that meant the heat pump could not keep up with the demand for heat. (Probably due to extreme cold, or undersized unit.)
If yu have heat, then at least one heat strip is operating. If you have multiple heatstrips, one or more could be malfuncioning.
Or it could simpy be to cold/to small fr your area and not able to keep up.
How many square foot are you trying to heat?
What is the outside temp?
What is the inside temp?
What size unit (BTU output) do you have?
Dec 22, 2008 | Haier Energy Star ESA3183 Air Conditioner
Continues to run
It seems your temp. control board or thermistor is not reading the temps and just keeps on running and running. Can you lower it to the lowest setting and (with a thermometer) see if the temps actually get warmer inside (will take a day or two to warm up). As for the ice on the bottom if the drain for the defrost cycle is plugged you may be getting water inside which then re-freezes. Let us know what you find and we can go from there.
Nov 26, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Sub-Zero 632 / S Logo
306 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
