Question about Holley 1986 Ford E150 Econoline 5.8L Mechanical Fuel Pump
1986 ford e150 fuel gauge not working - Holley 1986 Ford E150 Econoline 5.8L Mechanical Fuel Pump
Gauge not working
You have a bad ground at the dash display assembly.
May 29, 2014 | AM Auto Parts 2005 to 2008 Ford E150 Van...
My fuel gauge wont work
take of your truck bed or take your tank out
May 19, 2014 | 2003 Ford E150
Where is the fuel pump located in a 1986 Chevrolet Aerostar
Fuel pump is located inside the fuel tank...
Fig. 2: The fuel pump and fuel gauge sender assembly (click image for zoom)
The fuel pump locking ring can also be removed using a brass drift.
Hope this helps (remember to rate this answer).
Mar 23, 2011 | 1986 Ford Aerostar
Fuel gauge on 1986 e250 doesnt work
CK THE FUEL GUAGE BY GROUNDING SENDING UNIT GUAGE WIRE IF GUAGE GOES TO FULL SUSPECT BAD SENDING UNIT IN TANK ,BUT I HAVE SEEN THESE HAVE BRASS FLOATS AND THEY WILL FILL UP AND SINK TO THE BOTTOM TO INDICATE EMPTY
HOPE THIS HELPS
Aug 08, 2010 | 1986 Ford Econoline
I need a belt routing diagram for a 1986 ford
goto auto zone or advance auto they'll be glad to print one out for you "no charge".
Jul 04, 2010 | 1986 Ford Econoline
86 e150 w/FI 5.0. no power to fuel pump system.
If pump does not work when power is directly applied, then pump will need to be replaced. Have you tested the power from the fuel pump relay?
Aug 24, 2009 | 1986 Ford Econoline
Need wirning diargam for 1986 ford e150 windows
Haynes manuals have very good wirering diagrams.
Jun 28, 2009 | 1986 Ford Econoline
When replaced the fuel send unit the fuel gage sits on empty
Try grounding the gauge wire at the tank. If the gauge and wiring are good the gauge will go way past full when you do this.
Mar 01, 2009 | 1986 Ford F 350
Holley 1986 Ford E150 Econoline 5.8L Mechanical Fuel Pump Logo
42 people viewed this question
Top Holley Plumbing Experts
bobalix
Gil Shultz
Jerry Kramer
Jerry Kramer
Are you a Holley Plumbing Expert? Answer questions, earn points and help others
