Question about Royal 15MX Shredder
Manual for royal orca 9512x crosscut paper shredder
  • 1218 Answers
SOURCE: I need a parts diagram and part no.'s list for a
To order parts give Royal a call at 1-800-524-0799.
Posted on Aug 22, 2010
  • 1218 Answers
SOURCE: paper shredder jammed
Yes....this is a consumer model....NO BIN/BAG FULL INDICATOR....to keep costs down, you will just have to try to get the bin out a little at a time and slowly reach-in and "fish out the shredded paper...once you have enough out the bin will come out...hopefully the backed up paper has not jammed the machine and blown the PCB inside.....if it has give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Aug 31, 2010
  • 1218 Answers
SOURCE: Royal Orca 9512x shredder will not run. I have
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Posted on Sep 05, 2010
  • 1218 Answers
SOURCE: Lost Manual for Shredder
Not on-line that I know of but give them a call at 1-800-524-0799 maybe they can fax or e-mail something to you.
Posted on Oct 19, 2010
  • 11800 Answers
SOURCE: Royal Crosscut Paper Shredder Repair 15MX Paper
You need to unplug the machine, dismantle it completely - the instructions on how to do that are in the manual - and remove the blockage, something other that paper has entered there, most likely a clip or something similar.
If you no longer have it then you can call at their support section at 908-429-4357 Monday-Friday EST. and they will guide you. If you aren't very skilled in these sort of jobs you should take it for a service - it will be fixed almost surely on the spot . Use this toll free number 1-888-261-3888 to contact a Service Center near you.
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
I have a Royal Orca 9512x paper shredder. When I use it , it makes a very loud ,metallic squeeking sound. How can I correct this? It shreds fine. It's just noisey.
To fix this get some dry Graphite spray lube....
Spray graphite
Spray this on the cutters and sides of the cutters to lube the cutters and bearings....this will stop the noise...and prolong the life of the machine...
heatman101
Jun 18, 2011 | Royal 15MX Shredder
Royal Orca 9512x shredder will not run. I have checked the fuse and it is good. Cleared a paper jam and still wont run forward or reverse.
Sep 15, 2009 | Royal 15MX Shredder
Fuse Cover for fuse
For parts give Royal a call at 1-800-524-0799.
Aug 11, 2009 | Royal Office Equipment & Supplies
Royal Orca 9512x was moved to another room and now it won't turn on. A square piece of plastic fell into the basket. But we can't tell where it came from. Not sure if that's related or not.
Make sure that switch on back right foot is setting down on paper bin. It makes the contact that turns all on. I also had to use swithc cleaner from Radio Shack to clean my main swithc on top control panel.
Jul 12, 2009 | Royal 15MX Shredder
Wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Jun 10, 2008 | Office Equipment & Supplies
Royal orca wont forward will reverse shredd.
May have paper bits jammed above fixed curved metal surface that spiral cutter slices against.  Need to spend time removing built up material with stiff wire or flat tool.
May 04, 2008 | Office Equipment & Supplies
Royal 15MX Shredder Logo
415 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
