Question about Cub Cadet Street Sign- tractor lawn riding mower parts
1050 5 yr old Cub Cadet is sucking fuel, smell like gas when you operate it and uses twice what it use too
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: cub cadet 1050 fuel problem
Hi again.
Ok before I go on you can download a free Kohler service manual for your engine here:
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2574_a.pdf
If you have removed the input fuel line just after the filter and there is still no gas it leads me to believe one of 3 things
1. That the fuel tank vent is not open
2. The fuel filter is clogged (100 hr replacement interval)
3. The fuel tank outlet has debris in it,
Have you removed the fuel hose before the fuel filter and checked for fuel flow?
The carb itself has a fuel shut off solenoid on the very bottom of the carb. You can try putting battery voltage on this solenoid and see if it starts normally. If it does then there is a problem with power to the solenoid some where between the ignition switch and the solenoid. ( I just doubt this is the problem because you can add gass to carb and it starts )
This carb also has 2 jets in the bowl area a slow jet located under a rubber plug and the main jet (center) The slow jet can be clogged but again this would usually result in the engine not idling.
From what I am reading per your statement: "I empty the gas filter that connected to the fuel container and I do not see that the gas filter is filled again with gas."
Every thing there is BEFORE the fuel pump. This still has me thinking
1 filter
2 tank outlet clog / restricted
3 fuel vent problem
Pull off the fuel line "after" the fuel filter and remove the fuel tank cap. If you get a gush of fuel you have a vent problem.
Lastly the fuel pump diaphram is pretty fragile. Hopefully you did not damage it when you blew air into the fuel line. (been there done that!)
For on line parts diagrams you can use this link:
http://www.jackssmallengines.com/help.cfm Left side of page middle of page
(drop down menus)
kohler engine
courage series
SV720S
then select your model engine that ends in 0010 - 0032
Bottom line the problem appears to be before the engine from what I see.
Kelly
Posted on Jul 26, 2010
kjhbwertgr
Hi, I found manual on amazon, so you can check there for solution: International Farmall Cub Cadet 1000 Operators Manual Paperback July 20... I hope I have helped. Cheers
Posted on Dec 01, 2014
There is a flashing symbol- black rectangle with two white triangles one on top of the other mower stops but will restart after a few minutes. Cub Cadet LTX-1050, v twin1 Hydrostatic
Make sure air filter is clean or replaced. Check oil level. Change oil if not done this year. Remove plug, clean and gap. Ensure gasoline isn't over 30 days old and use a gas stabilizer if gas cap isn't marked E85.
Jun 18, 2016 | Cub Cadet Garden
Does cub cadet LT 1050 have a fuel pump?
some do, some don't depends on where the gas tank is usually .if under the seat it will have a fuel pump . most are vacuum operated . Open hood and look just in front of where you sit on the motor , there will be a black part with 3 hoses attached to it
Nov 02, 2015 | Cub Cadet Garden
How to replace drive belt on cub cadet 1050
Fairly easy to replace once the deck and the electric PTO are removed just make mental notes or rough of the belt path before removing the old belt. One thought if I remember correctly this uses 7/16" belt and a 1/2" width will not work due to the tight clearance at the engine pulley so stick with OEM belt.
Oct 14, 2014 | Cub Cadet Garden
Brand new ltx 1050 cub cadet kohler 24hp engine acts like it is running out of gas have changed gas 3 times still wont run more than afwe seconds
More than likely your carburetor has trash and stopped up and needs to be removed and cleaned. The reason it's doing that is because when you crank it the trash in the bottom of the bowl on your carburetor is shaken up and causes the obstruction and blocks the gas from going into the intake where it mixes with air and allowed to be sucked into the cylinders and ignited by the spark plugs. Hope this helps
Sep 19, 2014 | Cub Cadet Garden
Cub cadet manuals pdf
something clogging jet in carb water in gas rebuild carb
Sep 06, 2014 | Cub Cadet Garden
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
Sep 02, 2014 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Hello I have Cub Cadet LTX 1050 VT Sv720 23 HPEngine Kohler
This situation is just a clogged fuel line IN the tank. It happens. Yeah, stuff that gets In builds up in the line an elbow and plugs it up. Just pull the connection out of the tank and clean it out. I have even found plastic bits clogging the line on mine. I have a LT 1050 also. And a Cub ZT I just love.
Apr 26, 2017 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
18 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
