Question about Rolex Day-Date President 118239 Wristwatch
Rolex Oyester Perpetual watch stopped without any reason
I have a Rolex Oyester Perpetual watch which just stopped working all of a sudden. I would like to know what the problem could be and if it is battery operated. It has been 7 years and I never experienced this problem. I have misplaced my watch catalogue.  Please advise. Thank you.
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
unscrew the winding pin until it opens to the first position. (this position is for self winding. approx 30 turns clockwise will fully wind the watch)pull pin to the next position. this sets the date if it is a quickset. 1985 to present. again turn clockwise to the desired date is present. pull the pin to the final position and this will set the time turning clockwise as well. hope this helps.
Posted on Jan 05, 2009
SOURCE: operating instructions for a replica Rolex
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
Posted on Apr 23, 2008
escapement
  • 2334 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
  • 2334 Answers
SOURCE: how do i wind and set my Rolex Oyster Perpetual watch
After all settings being done, always screw the crown back down as it protects the watch from water and moisture.
Posted on Apr 04, 2009
SOURCE: Can you please tell me how to set my Rolex Oyster
24 hours passes and the day and date do not change. Does it need service? Have I broken something? I can pull the crown out 2 notches and change it manually----but it doesn't operate automatically. thanks brucesimons@sbcglobal.net
Posted on Dec 03, 2009
"Rolex oyster perpetual dateadjust" stops once in 2 days or less. starts on shaking the hand. advice?
try winding by using the crown see how long it goes for it may be the bob weight is not working or as come loose
Jul 16, 2016 | Rolex Datejust Watches
I need information (and where do I purchase one) to find the correct staff number for a 1945 Rolex Oyster Perpetual Bubbleback size "N movement. Dial side reads N-A 9215 18 Rubis 6 Positions
If you're looking to purchase a watch like this, I suggest you go to RolexForums.com to learn more about this model and find a good source for vintage Rolex watches.
Sep 13, 2013 | Rolex Rlxl010 Lnib Oyster Perpetual 67193...
The date and day have stopped working on my replica rolex daydate i have adjusted the pin several times but it is still not moving?
Your calendar wheel is damaged. Unfortunately, it is illegal to own or work on a Rolex replica / fake Rolex as it is a trademark violation. I would suggest purchasing a genuine Rolex as a replacement, as there are generally no identifiable movements, and therefore no identifiable replacement parts for the movement in your timepiece.
Be aware, however, that all automatic and mechanical watches, such as Rolex, must be services regularly, every 3-5 years, for them to last and work properly. Thanks for the rating!
Dec 16, 2012 | Rolex Oyster Perpetual DayDate 118239BKSP...
Cloudy face of my rolex oyster perpetual date, womens
Dont swim with it anymore - Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Jul 16, 2012 | Rolex Watches
1987 rolex president If watchis left sitting for about 10 hours it stops possible problems?
Most Rolex watches have a perpetual motion, that is they have no battery, and rely on wrist/arm movement to keep them going.
This maybe is why your watch stops after you have taken it off.
Mar 20, 2011 | Watches
Oyster Perpetual Day Date keeps stopping
That does sound like a peculiar problem. Without looking at it it's difficult to say. It possible the date change - stopping situation is co-incidental. All mechanical watches, particularly high quality one such as this should be serviced every two to three years to ensure optimal performance and preserve their value. I recommend you take it to a qualified repairer. Good luck.
Jul 28, 2009 | Watches
Rolex Day-Date President 118239 Wristwatch Logo
169 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
