Question about Compaq Presario R3000 Notebook
My CD/DVD drive does not work
When I put in a CD or DVD, the system activates (hear the whirrr) but it stops and does not recognize that there is a CD installed. I do not get any error messages....just nothing.
  • jpn5777 Mar 12, 2009
    It does not show up. Only the C, X and F (when a flash drive is in) show up. BTW... what is an " X: bin$ on 'barney' "??
  • Mark Van Skiver May 11, 2010
    Have you checked in my computer to see if it is there?
  • 76 Answers
Have you changed the cd and install a music cd if it still does that same thing chances are you need a new cd drive
Posted on Mar 12, 2009
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
I have bought a new piece of editing software ive checked that it runs with vista but every time i insert the Cd in to the drive it does not seem to recognize that thers a cd in the drive
try to run the cd on another system. if the computer recognizes that there's a cd in the drive, that may mean that your DVD Drive may be going bad. Usually DVD Drives dont fail all at once. it happens gradually. 1st it stops playing some dvds, then it stops playing dvds altogether
Mar 31, 2011 | Compaq Computers & Internet
Blank cd's are not recognized by the Dell Inspiron cd burner
I would first try removing the device in the control panel, system, device manager and then reinstalling the driver. There may be a problem caused by a windows update. In general CD drives rarely go bad. If the CD works say for a music CD then it should work for blank cd. You may also want to check the CD type. If you accidentally used a DVD, that won't work and in some of the older CD drives, they may not handle every type of CD format.
Good Luck
Feb 02, 2010 | Dell Computers & Internet
Will this drive work on a vista 64 bit system?
Try putting the same disks into some other CD/DVD reader, to confirm that the disks are "good".
It definitely should work in XP, XP/64, Vista, Vista/64,
but you could have the misfortune to have purchased a "lemon", i.e., a factory-defective unit.
Got another computer to which you can temporarily connect the new drive, to confirm that the drive will work "somewhere" ?
If all else fails, take it back to the retailer, and get them to demonstrate that it works in one of their computers, using your disks. If it does not, then they should replace it with one that CAN read your disks.
Nov 27, 2009 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Dvd/cd drive device properties state drive is
Apart from DVD, dose it recognize other Cd's? If is does then I think the lens for your drive is weak.
And if it is not the lens, then maybe you should uninstall the drive, restart your system and reinstall the drivers for drive.
You could also detach the drive from your system, while the system is shut down, then put on the system back without the drive, allow it to boot, shut down, put back the drive and see if the drive will play DVD this time.
Best wishes
Nov 10, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
My D drive (CD's) is not recognized by the computer
Give dell a call first
other wise see if you can roll back the date
Jan 28, 2009 | Computers & Internet
Cd dvd drive not recognized
Hi, it is usual to drives not recognized if it is new and connected to the system. Now, try this one to make it active. Go to Control Panel, Performance and Maintenance, Administrative Tools, Computer Management.
Under Computer Management, expand Storage->Disk Management. On the results panel, Right Click the Volume(X:) then click Mark Partition as Active or click Reformat.
*I hope this fixes your problem. If you have problems, please drop me a comment and I'll gladly help you.
Jan 26, 2009 | Acer Aspire 5100 Notebook
Nextech esdvd100 stoped recognise dvd/cd
I have the same problem with my esdvd100 were it stop recoginze my dvd or cd. msg: No Disk
Jan 04, 2008 | NexxTech ESDVD100 System
Compaq Presario R3000 Notebook Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
